  • Guests: 80
02/03 Bauerb2 (36)
02/04 Fabio (46)
02/04 Corey (35)
Comparing power transformer ferrite materials
Electra
Thu Jan 26 2012, 01:27AM
I agree with everyone else the N30 doesn’t look anywhere as good as the 3C90, for this.
Thought it may be similar to N27 which is still worse than 3C90,
But the N30 appears to have a very high initial permeability, so perhaps that could shed some light on what this would be typically be used for.
Kizmo
Thu Jan 26 2012, 06:15AM
nwm, my bad. These T65/N30 materials are meant to be used as high power chokes (common/differential mode)
That explains a lot cheesey
Thu Jan 26 2012, 07:41AM
Hi Kizmo,
May I ask what was in the end with those big soviet toroids you bought?
Thu Jan 26 2012, 07:45AM
Kizmo wrote ...
yep i thought so!
with power ferrites for inductors and transformers, ive always seen the traditional loss and volume graph...
Kizmo
Thu Jan 26 2012, 08:00AM
Dr. Dork Corrent wrote ...
Hi Kizmo,
1327564795 599 FT133054 Imag0213
Thu Jan 26 2012, 08:26AM
how well does you 879B work Kizmo?
mine is the older one the dial one, with only the basic LCD screen.
Kizmo
Thu Jan 26 2012, 08:35AM
Really well, i have nothing bad to say about it :)
(of course i dont have another same price range lcr meter to compare with but still...)
Thu Jan 26 2012, 09:14AM
I killed my 875B with a cap that self recovered some charge after i discharged it i think it was 220 USD 3 years ago.
So ill advise you to be careful.
Kizmo
Thu Jan 26 2012, 10:04AM
I have learned that lesson years ago when i killed almost new Meterman 38XR with similar accident... was 300eur meter
Thu Jan 26 2012, 10:51AM
That looks awfully like a ceramic ring magnet for a loudspeaker, not a "toroid".
Kizmo, try magnetizing it with a bigass electromagnet, and see if it holds a magnetic charge. A similar coil setup to a HDD platter launcher ought to do it, but you have to use DC or a pulse that doesn't reverse. Or if you have a large neo magnet you can use that.
These magnets ought to be "anisotropic" - they only hold a charge in the direction that is used in a speaker. That would also explain the dismally low inductance for a field in the toroidal direction.
