  • Guests: 46
Tesla capacitors
Patric
Tue Jan 24 2012, 05:23PM Print
Patric Registered Member #2899 Joined: Wed Jun 02 2010, 06:31PM
Are those capacitors good for a Tesla with a 811a tube on +/- 1000V? :10kV 4700pF High Voltage Ceramic Capacitors HV ham
They are rather cheap, I cannot afford much more...
teravolt
Tue Jan 24 2012, 05:40PM
are they RF rated?
Tue Jan 24 2012, 06:01PM
Those capacitors are not good for sgtc use but would work
they are quite high loss at TC frequencies and the sparks somehow aren't so 'snappy'
Notice also that they are rated for use in oil or resin, in air halve the voltage rating.
Dr. ISOTOP
Tue Jan 24 2012, 08:35PM
Patric wrote ...
Sounds sketchy and Chinese, so I'd be inclined to tell you to spend a bit more on real RF rated caps.
It'll be a lot more efficient and might even save you money in the long run.
Herr Zapp
Wed Jan 25 2012, 07:32AM
Patric -
If you're talking about the little (fingernail-sized) ceramic disk capacitors found under your description on eBay, then no, they're not suitable for the tank cap in an 811A powered VTTC. There are lots of small-to-medium sized mica transmitting caps (either used singly, or in an MMC config.) available inexpensively on eBay that will work well at the frequencies and current levels seen in a small VTTC.
Herr Zapp
Patric
Wed Jan 25 2012, 03:52PM
Thank you all... I will look for: mica transmitting caps ... Hopefully not too expensive...
