  • Guests: 47
New child sized tesla coil gun.
Staci
Sun Jan 22 2012, 11:12PM Print
Staci Registered Member #1741 Joined: Sat Oct 04 2008, 02:45AM
There aren't enough cordless drill became Tesla coils out there. Despite it seeming anti-climactic after the cordless circular saw tesla coil - I had to do it anyway. This one uses me as the RF return :)
Baby LG2
RogerInOhio
Mon Jan 23 2012, 12:33AM
RogerInOhio Registered Member #1034 Joined: Sat Sept 29 2007, 12:50PM
Cool, I like the fact that it is cordless. It reminds me of the violet ray machines they had during the early part of the 20th century which were used for medical purposes.
Killa-X
Mon Jan 23 2012, 02:54AM
I always knew these were possible, but, I need to understand it more. I know, your hand makes contact with the bottom of the secondary. So in turn, your body acts as the ground plane required for tesla coil operation. But, With one of these, I have to wonder. If you touch a grounded object with left hand, while 'shooting it off' with the right hand, Would you feel anything? Seeing your now providing a direct root to ground or....no?
I should consider building one, but I always wondered those risks, and if more power, could do any harm. I mean, if you want to, you can add Burst mode. Shoot a bolt every second, and have it charge some capacitors to say 200 volts (i mean like 5600uF+)...From experience with my large SSTC, that can kick out a 1ft spark or more. So your burst mode, can do the same, from such a device. Question is, would that possibly harm you..?
I'm eager to learn =P
jnbrex
Mon Jan 23 2012, 04:09AM
jnbrex Registered Member #3950 Joined: Wed Jun 15 2011, 12:45AM
Imagine that as a glove with 5 electrodes... Force Lightning!!
Can you please post a schematic of this wonderful invention?
Tetris
Wed Jan 25 2012, 03:59PM
Woah! Also, I don't know if it is my school's system that is blocking a video or something, but is there a video of this? (I am viewing this during my computer class)
EDIT:
Holy crap! It's like the taser of the future!
Staci
Wed Jan 25 2012, 07:23PM
Here's the inside - I'll post a schematic soonish when I get a chance. It's a bog standard Max913 driving a half bridge tho.
1327519405 1741 FT132913 Baby Lg2
Polonium210
Wed Jan 25 2012, 11:38PM
Polonium210 Registered Member #3450 Joined: Sun Nov 28 2010, 05:01AM
Very cool!!! So you aren't using a BLDC motor to run this one like your other one? This is running totally off the 18v drill battery? What are you using for feedback?
Staci
Thu Jan 26 2012, 12:51AM
This one use a 18V to 40V boost converter. There's also a fan inside the white pipe (40mm)to suck air in and cool all the guts.
dude_500
Fri Jan 27 2012, 06:15AM
dude_500 Registered Member #2288 Joined: Wed Aug 12 2009, 10:42PM
How many watts does it run at? Wondering how it compares to my hat coil which I have run at 200V boost 300W
Staci
Fri Jan 27 2012, 02:58PM
Is about 15 watts. Transistors barely get warm. Boost converter runs cold to the touch.
My 18V lightning gun (saw based) is 300W and discharges 20"+...that's also on my youtube. Incidentally, great work on the hat! Was that you in the hackaday article?
