  • Guests: 63
RoV IW3IPD (63)
01/12 RoV IW3IPD (63)
Need single pulse from ignition coil
1 2 3 4
RonP
Fri Jan 20 2012, 05:35PM Print
RonP Registered Member #4361 Joined: Fri Jan 20 2012, 12:46AM
Help please. I have need to produce a single pulse of 15kV or more. I know how an automotive ignition coil works and thought i could simply pass current through the primary and interrupt it, and get the pulse out when the field collapses.
I connected one terminal of an ign coil to 12-volt power supply (20 A capability). I grounded the other terminal with a clip lead and disconnected it. I expected full output, enough to jump a spark plug but I only get 1 kV or so.
Fulmen
Fri Jan 20 2012, 05:45PM
Fulmen Registered Member #3883 Joined: Fri May 13 2011, 06:30PM
You need a small capacitor in parallel with the switch, this will prevent arcing at the primary when the current is interrupted. It also keeps the voltage down to the intended range. Start with a .2uF, rated at 200V minimum. The larger the cap the lover the voltage, so you can easily tune the coil to the correct output.
RonP
Fri Jan 20 2012, 06:42PM
Fulmen: thanks for the tip; i'm getting HV pulses now. I'll likey replace the mechanical switch with a FET; then I'll play with the cap values to get the right voltage.
Fulmen
Sat Jan 21 2012, 01:38PM
That should work fine. Just don't run it without a cap or a safety spark gap or you're going to fry the FET.
RonP
Sat Jan 21 2012, 05:47PM
Thanks but I've got that solved. I used a IRF644 FET and protected it with a P6KE200 overvoltage protection zener (cathode to FET drain, anode to FET source). Normal zeners can't handle the pulse energy. Just to test it, i ran the coil without a cap. I'm puzzled now whey i couldn't get any pulses out earlier. I think the first coil may have been defective. Thanks for your help; you got me on the right track. I can now generate arcs about 2 cm long. Charts suggest this should be >20 kV. Good enough for my experiments. Now i'll add a monostable 555 pulse to drive the gate and it will provide consistent results..
Sat Jan 21 2012, 07:43PM
It isn't possible for an ignition coil to output a single pulse - what you will get from a single input pulse will be a train of damped waves from the output, as we are talking L, C and R here.
You could sharpen this up a bit by placing a spark gap in series with the load if you wanted to.
RonP
Sat Jan 21 2012, 07:59PM
Mary, Good point: it depends on the effective Q of the circuit. For my purpose, a large pulse and declining train of small ones will be fine.
Fulmen
Sat Jan 21 2012, 08:14PM
If you tried to switch a coil mechanically without a capacitor you will loose most of the energy in the arc formed between the contact points. As the current is interrupted the voltage will increase instantaneously towards infinity, causing an arc at the low resistance primary side.
RonP
Sat Jan 21 2012, 08:29PM
Fulmen: I'm sure that explains the early failure I had. The addition of the capacitor you suggested made it work. Then the FET made it better. That also explains why a capacitor ("condenser" in US autos) allows an auto distributor to fire properly.
Alternatively you can use 'capacitor discharge' to make a single pulse
Charge a capacitor to about 300 to 400 Vdc then discharge it into the primary
(You could use rectified ac mains (cautiously), a camera flash charger etc.)
A thyristor would be a good switch for this purpose,
a relay contact would work but wear out quite quickly.
