  • Guests: 49
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
SSTC controller CD4046 and UC3845
Redstone
Thu Jan 19 2012, 09:51PM Print
Redstone Registered Member #2578 Joined: Sun Dec 27 2009, 09:21PM
I have decided to share an idea on SSTC (IH too maybe) controller design useing a CD4046 with a UC3845. I believe this would give a lower parts count mostly. Iam not sure if all of the UC3845 can keep up so that will need to be explored.
UC3845 use as a OCD for controlling current and possibly voltage in the primary coil. The CD4046 for controlling frequency and running oscillator.
anyone interested please comment!
Note schematic is not tested and is wrong
1327009773 2578 FT0 Sstc Controller2
teravolt
Thu Jan 19 2012, 10:45PM
genraly people use a variac to controle power so you could use the 3845 ie PWM to controle power to mains dublier and 4046 to tesla conrole. If you try to to PWM the tesla you could excite the harmics in the tesla wich would not be good. it would be the equivalent of harmonic destortion onless you filter the secondary fundimental Fo from your feedback.
Redstone
Thu Jan 19 2012, 11:28PM
I was not thinking of useing the 3845 for PWM, but for over current detection.
I will edit that into the first post to clear that up.
teravolt
Fri Jan 20 2012, 05:53AM
the uc3845 is current mode PWM and a strange coice to merry to a 4046. I kind of see what you want to do to use the 4046 to drive the oscilator input on the 3845 and PWM the gates of your fet's using a CVR. I asume to controle fet current. I still think that hamonics will screw with the 4046. the best way is 1 to simulated if you had models or 2 breadboard it and test it out on a small scale
Redstone
Fri Jan 20 2012, 07:24PM
Ok, I think harmonics could matter more from where the feedback is coming from, primary or secondary.
so It will have to be tested and I will make a schematic that is a bit more complete. if anyone else wants to help testing and designing feel free to comment and share.
