  • Guests: 37
williamn (48)
ReddyK (57)
Birdman (31)
12/14 M.A.D. (32)
12/15 marko666 (58)
12/16 Will T (16)
Bunch of stuff for sale/trade
Inducktion
Sat Jan 14 2012, 09:25PM Print
Hey all!
I was downstairs, and was picking through the stuff I won't need... :D
Some assorted fans, smaller ones are $2 each, larger, $4 each
Tiny 5 volt SMPS, just supply 120 vAC to it and bam instant 5 volt supply. (I do not know the max current, however)
I need to add a 100 ohm resistor onto it before I sell it. Remind me if you decide to buy it!
$5 for it
little bigger SMPS... Supplies 18 volts at 1 amp, if memory serves me correct.
$6 for it
Even bigger 5 volt supply. Can give out +5 volts at 3.5 amps, or -5 volts at 2.5 amps. I can give you the pinout if you wish to buy it.
$10 for it.
a 30 pF mechanical tuning cap... It would make a nice radio transmitter/receiver!
$1 for it.
1 GB memory sticks DDR2, I got two of them, 667 mhz. They work, and would make a pretty nice upgrade for your older laptops!
Asking $4 each, or $7 if you buy them together.
A Stanley Recon Mica cap. .25 uF, rated at 1000 volts peak. Great for a variety of things.
$5 for it!
Small electrolytic caps; rated at 150 vDC, 560 uF.
Asking $1.5 for each of them
Bigger electrolytics; Rated at 350 uF (though, I measured them with a C meter, and they're actually above that still!) Can handle 450 vDC, great for filtering and coilguns too!
Asking $3 each.
These electrolytics are the same size as the previous ones physically. However, they are rated at 550 uF, and can handle 250 vDC. Also great for filtering! Also $3 each.
Link2 *NEW*
Maxwell Ultracapacitor. 2600 Farads, at 2.5 volts, this thing is a beast. It can melt steel, weld, and a whole bunch of other things too.
I'm asking $28 for it, and shipping is probably going to be a good 8 - 10 dollars for US buyers. For Canadian buyers it's probably going to be around $12-14.
Link2 *NEW*
A beefy two diode brick. Can handle 800 volts at 160 amps. Datasheet -> Link2
Asking $15 for it.
PM me if you'd like to make offers, or trades for any of the above items. I'll be pretty flexible with pricing, so please, ask!
USA and Canada only.
I have a paypal now too!
Thank you for taking the time to read!
UbuntuNinja
Sun Jan 15 2012, 11:36PM
UbuntuNinja Registered Member #2677 Joined: Mon Feb 08 2010, 03:06AM
Just a friendly heads up, both the arrow above the text about the PFC board and the text about the 30pF tuning cap link to a picture of the cap...might want to fix that. Also, I might be misunderstanding you but are saying that the PFC board might be suitable for a DRSSTC power supply? If so I might be interested in it
Inducktion
Mon Jan 16 2012, 04:24AM
Thank you for pointing that out for me.
And yes, the PFC board SHOULD be pretty good for a DRSSTC power supply; However, it can only supply around 400-500 watts with the current state it is in. If you changed the heatsink, it could probably handle a bit more power, but I don't know for certain. It's well built, that's for sure, as it was taken from a server PSU.
Inducktion
Fri Jan 20 2012, 04:57AM
Updated information!
Inducktion
Tue Jan 24 2012, 05:45AM
Lowered the prices on everything.
Inducktion
Fri Jan 27 2012, 04:18AM
Some more stuff was added.
