  • Guests: 45
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Mini PL504 Vacuum Tube Tesla Coil .
TwirlyWhirly555
Sat Jan 14 2012, 03:52PM Print
TwirlyWhirly555 Registered Member #4104 Joined: Fri Sept 23 2011, 06:54PM
Hi ,
My First Real Post here i finnaly made a tesla coil , First one i have made is a Pl504 based Coil , Secondray is so many turns of 0.1mm Wire , theres about 5 inches worth of windings .
There is a topload i guess you could call it that , its a small screw and it seems to make the arc abit bigger/more corse . The Tank Cap is 1nF , made from 4 ceramic Capacitors that are kinda naff . I have a 811a Tube on the way to make a bigger one soon , was just so happy my first coil works with fairly good output :) .
Here is a video , Link2
Sat Jan 14 2012, 07:20PM
Hi,
that is pretty good output, what circuit are you using?
Here's mine: Link2 (wait for the switch to high power mode).
TwirlyWhirly555
Sat Jan 14 2012, 07:50PM
Hey ,
Thanks , Im Using Your Circuit i belive from your mini PL504 Coil :) , saw it a few days ago and attempted it , worked out pritty well :) , Nice Coil you have , any idea on res frequency ?
I shoudl try and find seondarys frequency really but for just chaning cap sizs around im pritty pleased with the out come :P , secondary is 1" by 6" .
Sat Jan 14 2012, 10:37PM
I think the coil ran at around 700 kHz and the secondary calculated resonance was around 1 MHz.
TwirlyWhirly555
Sun Jan 15 2012, 06:38PM
Hi ,
ok thanks , what did you end up with for Primary and feedback turns ? , I just stayed with 15 and 15 turns .
Sun Jan 15 2012, 08:01PM
I think it was 18/17, though I would have used less for the feedback now.
