  • Guests: 58
Which is better,antenna feedback or secondary base feedback?
hsieh
Sat Jan 14 2012, 03:02PM Print
hsieh Registered Member #1412 Joined: Thu Mar 27 2008, 04:07PM
When building SSTCs,why most people use antenna feedback instead of secondary base feedback?Are there any advantage or just because simplicity?
I also noticed that although most people use 74HC14 in the feedback part of the circuit but some design use a comparator such as steve's SSTC1 and 2 Link2 .Which is better?In this Link2 thread someone says a comparator is better for a DRSSTC.How about SSTC?
thanks
Ben Solon
Sat Jan 14 2012, 07:47PM
for the feedback question, there are tradeoffs. if you use an antenna, the coil wont recieve feedback when the secondary is loaded by drawing an arc. i have rarely seen a sstc with secondary feedback however. i always thought it was more of a drsstc thing. go with the antenna unless you want to be constantly drawing arcs.
Sat Jan 14 2012, 09:43PM
I think most people use antenna feedback because it is simpler and most of the schematics out there ue it. Base feedback is beter in almost every way, but it requires winding the transformer, which wile not hard to do is a pain for most people.
