  • Guests: 68
Primary Capacitor
zzz_julian_zzz
Mon Jan 09 2012, 06:02AM Print
Is it worth it to build an MMC using MKT capacitors? planning to make 200nf @ 6KV ,.
Each capacitor is rated 330nf@600v
Thanks in advance
Dr. ISOTOP
Mon Jan 09 2012, 06:49AM
Coil size/power? 6KV is awfully low, and 200 nF is awfully high.
I wouldn't use anything that's not a CDE940/942 in all but the smallest coils.
zzz_julian_zzz
Mon Jan 09 2012, 08:59AM
DRSSTC
SECONDARY:
6 inch diameter
24 inch height
30 awg wire
fres : ~100khz (torroid will just follow to meet low freq)
MMC:
200nf
PRIMARY:
12 turns .25 copper tube
BRIDGE:
Half bridge of IRG4PC50UD igbts
>EVR used 6 kV on his Minibrute also, 110nf primary capacitor
Dr. ISOTOP
Mon Jan 09 2012, 10:21AM
Oh its a DRSSTC...in that case the 6KV makes sense.
I would definitely go CDE over no-name caps in that case.
Gregory
Mon Jan 09 2012, 04:22PM
I'm using some yellow MKT 470nF x 2000V for my 10 foot spark DRSSTC witn no problem
zzz_julian_zzz
Tue Jan 10 2012, 01:13AM
thanks for the inspiration gregory =),. how about if foil made caps?
zzz_julian_zzz
Mon Jan 16 2012, 06:05AM
Hey Gregory,
You said:
I'm using some yellow MKT 470nF x 2000V for my 10 foot spark DRSSTC witn no problem.
Is you primary tank rated 470nf at 2000v? normally DRSSTC required some several KV rated primary capacitors isn't it?
And why is that? why DRSSTC primary capacitor rated at several KV even if that the pulsed DC is only at range 350vdc?
Uspring
Wed Jan 18 2012, 12:30PM
It is the primary current that matters. The voltage you get across the caps is I/(2*pi*f*C). That can be much larger than the bus voltage.
Wed Jan 18 2012, 02:18PM
Yep, we usually design for a loaded Q of 10, which works out at a roughly 5kV tank cap for a fullbridge running on rectified 230V mains.
The primary current limiter (which every good DRSSTC has) will also protect the cap from overvoltage, because the capacitor voltage is related to the current through it by its impedance. The impedance depends on frequency, but the frequency of the coil doesn't change a great deal, so it can be assumed constant.
hsieh
Wed Jan 18 2012, 02:25PM
hsieh Registered Member #1412 Joined: Thu Mar 27 2008, 04:07PM
Someone told me that WIMA FKP1 is better than CDE 942 in high power application.Is this true?
