  • Guests: 50
Flyback Transformer Plans/schematic
1 2 3 4  last
GFH
Mon Jan 09 2012, 05:35AM Print
GFH Registered Member #4324 Joined: Mon Jan 09 2012, 03:16AM
Good day all,
First let me apologize for this post if the information is elsewhere. I just can't seem to put it all together and I am under time constraints
My son came home and said he needed to build something for a science fair project. I sad "cool, what is it?"
"An Anti gravity lifter" he says. I go "Way cool"..So I look at the info he dug up seemed easy enough except it needed a HV power supply. "Way cool" just became a PITA
So I began Googling. As you can surmise I have come up with plenty of ways to do it but not one I would say is complete. They are missing part numbers, schematics are inconclusive or simply state connect the FBT and your done.
Can someone PLEASE direct me to or give me a HV Flyback transformer power supply plans around (30kv) that will work?? Mosfet, 555, transistor makes no difference as long as one can figure out the plans.
The biggest pain is saying dig a FBT out of an old TV and use it. Except every FBT I find in a TV is completely different from the next and different from what is shown in plans. So plans with a tad more detail regarding the FBT would be great as well.
many thank sall.
I sincerely appreciate it.
Gord
Mon Jan 09 2012, 07:36AM
You should be able to whip up a usable HV source for his purpose.
My thread here is the best i can do -> Link2 flybacks vary and dont expect to find exact info on them. Your effort does not need to include so much as mine.
And just for clarity, stay away from the "anti-gravity" phraseology... especially if this is for a science teacher.
They are electro-kinetic devices, just as Newton would expect force--reaction pairs to behave. The Mythbusters and others have eliminated "anti-gravity" as a possibility in this devices operation.
They're still fun and way cool to play with, even for college students like me, just dont blow stuff up or burn stuff down.
EDIT: i first used a neon sign transformer a 12kV one, it just plug into the 120Vac socket, for my first gen lifters. kinda lame but it worked.
1326096344 2431 FT1630 Sam 0439
My carbon fiber 12" equalateral triangle lifter.
1326096344 2431 FT1630 Sam 0443
And from the top.
1326096344 2431 FT1630 Sam 0447
Instrumentation, anemometer and differentiential pressure meter.
1326096344 2431 FT1630 Sam 0897
All up, with everything needed to fly it wheighs just 6 grams, and operates from 30-45kV...
Some advice, dont bulid it heavy, build it so light and flimsy youll expect it to fall apart, build several, youll burn them or break them. The DeSeversky ion-wind effect is very weak even when you have enough V and I.
GFH
Mon Jan 09 2012, 04:57PM
Thanks Patrick
Sorry about the "Antigravity" moniker. It's what my kid called it when he first came home :) I'll call it what it is from now on.
I realize that there are a lot of different types of flybacks. I have three different ones sitting in front of me.
I'll go through your post and figure it out.
Perhaps you can clear something up for me
The one FBT I have has the HV out plus two others. Now as I can deduce, I use the HV line out (obviously) but I have to find the negative or other end of this line on the PIN end using a meter or whatever.
Save for the one pin that would serve as the negative for the HV line all other pins and lines are not used.
When folks talk about wraps around the core , I assume they mean taking appropriate wire and wrapping the exposed vertical ferrous "bar".
I have seen schematics which have say 10 wraps with a third tap off the center (wrap 5 lets say). Would one merely expose a bit of bare wire at this point and solder a third one on at this point?
Many thanks
Gord
1326128173 4324 FT131895 Fbt
H8erade
Mon Jan 09 2012, 10:08PM
H8erade Registered Member #3451 Joined: Sun Nov 28 2010, 11:13PM
GFH wrote ...
You can do that.
Usually, I just wrap two five-turn coils and connect them. The connection between them can be used as a center tap.
Platinum
Mon Jan 09 2012, 10:21PM
What driver will you be using, if you have no experience with HV, or building circuits, I suppose you can try to get a low power NST, or try a CFL ballast or halogen transformer ballast, they provide enough power you can get them up to 250W (halogen) , and that's alot of power for a lifter.
You can check my thread on halogen transformer flyback driver success. Very simple to make, all you need is a flyback, and a halogen transformer, and some wire...
Antonio
Mon Jan 09 2012, 10:36PM
Here are my "lifter" experiments and some power supply plans (the second picture is the best). I used the normal primary windings of the transformers. Simpler power supplies are possible, but too simple ones are unsafe and don't last for more than a few seconds.
GFH
Mon Jan 09 2012, 11:43PM
Hi guys,
Thanks for the ideas.
This HV stuff is new to me, electronics is not.
I planning on a FBT. Either the simple this one with 2 - 2n3035's Link2
or the ZVS one on the same page just couldnt find the mosfets today.
Some say they require power supplys capable 12-24 volts and 5-10Amps while other operate on a 9 volt cell.
I don't know whos right :)
Platinum, I'll take a look at your thread, just have to find it.
What I've come to is that there are no wrong ways to build one (well ok there are but I'm talking about ones that work) and 100 + right ways.
Platinum
Tue Jan 10 2012, 12:28AM
Antonio wrote ...
That's very good as input is 11Watts, I've tried to make a lifter but failed numerous times, maybe I shall try with the ZVS.
Tue Jan 10 2012, 01:40AM
i would wrap 10 -20 turns (no tap) around the ferrite leg, then use a single MOSFET or IGBT driven by a 555 timer, then use a computer UPS battery, a large one. maybe two in series...
To find the ground pin you hold the red fat wire near the horse shoe pins, which ever it sparks and arc to most fiercely is the ground pin.
the difference with power sources is total power avaibale, IE a 9 volt battery wont get a lifter up.
Alex M
Tue Jan 10 2012, 02:41AM
I would say a halfbridge might be the best option for a reliable lifter. The ZVS doesn't give much voltage, only high current which is not what is required for this to work. And single MOSFET drivers always fail within about 10 minutes of play.
How ever a large power supply is needed for large 3 inch igniting arcs.
 Copy
1 2 3 4  last
