  • Guests: 44
Primary Coil
earth3
Mon Jan 09 2012, 02:06AM Print
earth3 Registered Member #3721 Joined: Sun Feb 27 2011, 04:43AM
could i use any other material other than copper for the primary?
zzz_julian_zzz
Mon Jan 09 2012, 05:38AM
yes, but it won't be as efficient as copper(required). Probably it will cut the overall performance.,
steven968
Mon Jan 09 2012, 05:41AM
steven968 Registered Member #3516 Joined: Wed Dec 15 2010, 10:40AM
Alumainum tubing would be suitable, but the cross sectional area should be 6 times larger than copper.
Hope that make sense :)
Dr. ISOTOP
Mon Jan 09 2012, 07:39AM
earth3 wrote ...
Unless you're making a very large coil, one for which the primary metal cost becomes significant, it makes absolutely no sense to use aluminum. It'll be bulkier and have decreased performance.
Now, for a large coil this makes sense because the price per conductance of aluminum is less than that of copper.
earth3
Mon Jan 09 2012, 03:19PM
could i use a 3 foot wire with 1-2ohms resistivity? i dont know which metal it is. where can i find such thick copper for my primary? or can i use a 1000V wire the ones with insulation used for wiring houses?
Dr. ISOTOP
Mon Jan 09 2012, 03:26PM
earth3 wrote ...
Medium to large coils use soft 1/4" copper refrigeration tubing.
earth3
Tue Jan 10 2012, 01:56AM
where do i find refrigeration tubing?
zzz_julian_zzz
Tue Jan 10 2012, 02:20AM
you can easily get copper wire from your nearest hardware shop. for good mid range design/size, use size 8 awg, stranded or solid would do, but i recommend stranded for it is easier to bend, and has larger circumferential area compared to solids
earth3
Tue Jan 10 2012, 02:28AM
err i live in india it is hard to get such thick copper here!
zzz_julian_zzz
Tue Jan 10 2012, 02:38AM
ow okey, I didn't motice, there are no india indicated in your location
