  • Guests: 49
Barry (71)
Snowcat (38)
wylie (44)
02/01 Barry (71)
02/01 Snowcat (38)
02/01 wylie (44)
Peak primary current calculation
rulmismo
Sun Jan 08 2012, 10:16PM Print
rulmismo Registered Member #4187 Joined: Fri Nov 04 2011, 08:08PM
JavaTC gives me, with V1=8kVrms C1=40nF L1=5uH, about 1000A of peak current.
,anybody knows or have a reference of the formulae or derivation of that calculation?
I want to assure that my primary gets lower than 500-600A to avoid stress in my metalized film caps (that will support about 1000A nominal)
(see Link2
Regards!
Uspring
Mon Jan 09 2012, 04:26PM
Reactance of your tank is sqrt(L1/C1) i.e. about 11 ohms. Peak voltage is V1*sqrt(2) if V1 is given as rms, i.e. about 11kV. 11kV/11ohms gets you 1000A.
Mon Jan 09 2012, 05:24PM
Maybe you can find some use of this mmc calculator: Link2
rulmismo
Mon Jan 09 2012, 06:47PM
Probably I forgot my circuits lessons, but don´t get really what does it mean the "tank impedance" sqrt(L/C) here, and why it can be used as (Vc / Z) to calculate the Ipeak.
I see that it is the same value than the "characteristic impedance" of a line; is there is any relation?
I googled for LC circuit equations to get some info on the subject, but don´t got any clue about it (just the usual LC formulae about resonances etc.)
Doing a spice sim with primary data as series RLC, R=100m L=7u and C=40n, charged to 12000V i get a current of about 120kA!
this makes also wonder what is the order of the spark-gap resistance, once fired
as you can see, I am quite lost here, please help!
thanks
zzz_julian_zzz
Tue Jan 10 2012, 03:39AM
how did you get 120kA in your primary?
Uspring
Tue Jan 10 2012, 04:47PM
The tank oscillates at its resonant frequency given by f=1/(2*pi*sqrt(L*C)). In a way the capacitor can be seen as an AC voltage source connected to the inductance L. L is much like a resistor for AC, except, that there is a phase shift between the voltage and the current. The AC "resistance" of L is given by 2*pi*f*L and you can apply Ohms law to derive the current from the voltage.
In your simulation you probably looked at a series LCR tank driven by an input voltage. At resonance the L and C "resistances" cancel and your are left with a 100m resistance, which gets you the enormous currents. A SGTC works differently. Here the capacitor is charged up until the gap fires creating the tank. There is no input voltage apart from the initial charge on the cap.
rulmismo
Tue Jan 10 2012, 06:48PM
Thanks for the reply upspring,
In the serial RLC sim I just set the initial condition as Vcap=10kV and then run it. There is no voltage source apart from the charged cap.
Your argument could be ok, but in first post is said that "tank reactance" is sqrt(L/C), and this is the commonly used formulae seen, so I assume that is correct.
Now you just use L reactance for calculate the current?, this has not to be similar to sqrt(L/C) in general case, isn´t it?
Maybe someone can give some light to this topic
Uspring
Tue Jan 10 2012, 07:25PM
Note that the equation for the L reactance 2*pi*f*L also contains the frequency f. If you use the resonant frequency f=1/(2*pi*sqrt(L*C)), you'll get sqrt(L/C).
My response to your simulation was just a wild guess. I have no real idea, what went wrong with it. 120kA don't make any sense to me.
Tue Jan 10 2012, 08:47PM
In a resonant circuit, energy oscillates between the capacitor and the inductor. If you charge the capacitor to voltage V, one quarter cycle later V is 0 and all the energy is a current I in the inductor.
The ratio V/I is the characteristic impedance.
rulmismo
Tue Jan 10 2012, 08:55PM
Um, :-o, that f substitution trick seems to make sense
Steve, LC working is clear but from that is not straighforward that Ip=Vinitial / sqrt(L/C)
i adjoint the sim, I will try to sim with secondary to check if that could be the reason of the difference
http://www.megaupload.com/?d=AV6MWIBT
Update: sim with
primary c=40n L=7u R=100m
secondary K=0.13, L2=12mH c2=18pF (data from my coil in progress..)
same about 100kA peak primary result, maybe spark gap impedance could be the real difference, what do you think?
http://www.megaupload.com/?d=KE0CDXIZ
