  • Guests: 52
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Weak NST output
ZakWolf
Sat Jan 07 2012, 09:50AM Print
I got this small Francformer NST from a friend, previous use unknown(probably wasn't messed with just remove and sat on a shelf to collect dust). I wanted to make a small Tesla coil but I found that the arc it was supposed to create was only a millimeter long. :( Is it trash? Anything i can do to fix it ?
specs:
CAT.9030fm7
PRI.120v 60hz 270v.a
SEC.9,000v 30ma
1325929787 3114 FT0 003
1325929789 3114 FT0 004
1325929789 3114 FT0 002
Platinum
Sat Jan 07 2012, 10:00AM
Hmm 9KV, maybe there is a loose connection, and short inside, try to check it out. All though I'ma noob.
ZakWolf
Sat Jan 07 2012, 10:09AM
its encased in tar, so i cant look inside.
can the bottom be unscrewed and removed? my Franceformer needed a new switch, now works fine. but if you cant gain access to the internals in may be crap.
ZakWolf
Sat Jan 07 2012, 10:11AM
i can, i just did. i will look at the switch. Will any do?
EDIT: I replaced the switch and got the same results. It Vibrates a lot if i manage to sustain the one millimeter arc.
Sat Jan 07 2012, 10:48AM
SublimeVolts wrote ...
it sounds like the secondary is mostly lame... i dont know if its worth fixing, is yours filled with mica and tar like mine?
ZakWolf
Sat Jan 07 2012, 10:54AM
Patrick wrote ...
yes, i opened the case up and its a solid brick of tar
Antonio
Sat Jan 07 2012, 04:22PM
There are many documentations in the Internet about how to restore damaged NSTs. If the wiring is ok essentially you have to melt the tar, mix it a bit to destroy possible carbon tracks inside and let it cool again. Obviously something messy to do. Try to measure the resistance of the secondary winding. There are two coils with the center grounded (jn the case, I imagine). If you measure two identical resistances the wiring is at least not open. You can also check the short-circuit current. 9 kV should produce sparks with at least 3 mm.
thearisen
Sun Jan 15 2012, 09:45PM
thearisen Registered Member #4341 Joined: Sun Jan 15 2012, 07:09PM
Secondary's almost certainly shorted... depotting these things to fix them is an absolute pain in the arse, so unless you really can't get hold of another I'd say it's not worth the bother.
