  • Guests: 52
MiniSSTC Fet died on start-up; GDT problems?
Acacia
Fri Jan 06 2012, 11:11AM Print
Acacia Registered Member #4073 Joined: Sun Aug 28 2011, 08:43AM
I powered up my first SSTC (based on Steve Ward's MiniSSTC) today, and it looks as though one of the MOSFETS on the half bridge has failed.
The secondary resonant freq. is around 380kHz without topload.
I am almost certain it is my GDT.
The GDT core was found a long time ago, and I'm not sure it is ferrite as I remembered it was a noise filter in a power supply only after powering it up.
The wire was salvaged from a computer (the twisted wire that is used for buttons and led's).
All in all, I'm fairly sure this GDT is the cause of the fault.
I included pictures where the gate resistor of the believed faulty mosfet can be seen with damage to it's legs.
(sorry, my camera doesn't like to focus on small things)
On the HvWiki, an Al value of 4000nH/N^2 or more is recommended, and after a quick look on a local supplier website, I found this http://au.element14.com/epcos/b64290l618x38/ferrite-ring-core-25-3x14-8x10/dp/1422737
There is a link to the data sheet on the attatchment.
Would this be a good choice of core? I am planning to wind the core with a similar technique as steve ward, with the CAT-5 cable.
If this core is not suitable, what would be a more suitable core (with part number so it can be ordered)?
Thanks for any help, Nic.
1325848261 4073 FT0 100 0396
1325848261 4073 FT0 100 0394
dude_500
Sat Jan 07 2012, 09:10PM
dude_500 Registered Member #2288 Joined: Wed Aug 12 2009, 10:42PM
You can test the GDT, just put a test square wave into it (through a cap if it has DC offset), then scope one of the secondary windings. If it's a clean square wave, it's likely fine and proceed to test it with the load of a gate on it. If it's not good, it'll become evident quickly.
There are suggested models if you search old forum posts on the topic.
zzz_julian_zzz
Tue Jan 10 2012, 07:59AM
2 things I get to check before I can say that my GDT is up to work., first is physically, it should be black semi-magnet appearance / material, and of course my twisted 1 pair wire (24awg) can fit in at least I am targeting about 30 turns.
second is its sound. when supplied by my driver, even w/o feed by signal generator, the "ticks" should be heard and same as the interrupter do so.
also, in the secondary wire of the transformer, I can measure the frequency output liked as on the Interrupter, and the voltage(AC) around 1.5v. (I DON'T KNOW IF MY CRITERIA PROVES ANYTHING, but for me, everytime I seek for a possible GDT, I assure that the GDT passes these tests. And yet IT WORKS!
Marko
Tue Jan 10 2012, 08:46AM
Just checking, are you having that RED and BLACK wire going to the gate and source of a same mosfet?
Marko
Acacia
Sat Jan 14 2012, 06:51AM
no, it's all wired properly. I did that to keep the transformer secured
