  • Guests: 46
01/23 GimpyJoe (36)
01/24 OnFire (64)
01/25 Evgenij (60)
Super bright 1W LEDS
Alex M
Wed Jan 04 2012, 04:25PM Print
For all of you LED fanatics on here, take a look at these Link2
I requested 4 samples of them and they are pretty bright! They draw 400mA and have an Vf of 2.2v-2.8v.
Just though I would share that.
Chip Fixes
Fri Jan 06 2012, 12:48AM
Those are pretty cool, not sure if these require it, but most high power LED's need some sort of heat sink
Alex M
Fri Jan 06 2012, 01:02AM
Camp Badger wrote ...
I was thinking that but they are surface mount type and I can not see how a heat-sink would be mounted to them.
Although the data-sheet does say they can operate upto 120c.
Chip Fixes
Fri Jan 06 2012, 03:39AM
Oh ok, well if they can withstand 120C, it's probably fine. I guess you could mount on the pcb behind the led if you wanted but idk if that would do much
Fri Jan 06 2012, 05:26AM
Looks like fun. You know better than to stare at intense LED's.
The datasheet (linked in OP) includes diagrams and numbers related to thermal management.
LED efficiency and lifetime get better as the junction temperature is reduced.
Normally these emitters are surface mounted onto PCBs with large areas of copper foil to spread and dissipate the heat; in fact the datasheet has a chart of junction temperature vs. PC board area.
Your breadboard is better than nothing, but the copper heat-flow path is broken up.
Be creative and think about thermal resistance. Which terminal of the LED package conducts most of the heat?
[edit] the Vishay thermal information was not in the datasheet, but in an app note link
also found on the product page in OP.
Alex M
Sat Jan 07 2012, 12:31AM
klugesmith wrote ...
Are you saying it is a bad thing to stare into the die whilst it is on? cheesey
