  • Guests: 52
RoV IW3IPD (63)
01/13 si2030 (62)
I made a "different" flyback driver.
Platinum
Mon Jan 02 2012, 05:26AM Print
I was trying to build this: Link2
And I did, output of the mains multiplier is 1KV pulse.
So I took the outputs of this multiplier put them into a spark gap and then the spark gap to the flybacks internal HV multipler, I've been having quite some fun, although the spark gap fire about 5 a second pulses, that's the best I can get, and the flyback sparks to ground.
It's a spark gap flyback driver lol, capacitors dump energy into a flybacks internal multiplier and the flyback goes to earth, sparks are about 25mm. And they hurt. If the voltage would have been higher in the mains CW, then I can get the spark gap to fire much faster, but when the gap is closer the flyback sparks are smaller, lol same way a SGTC works.
ifryd
Wed Jan 04 2012, 11:47PM
ifryd Registered Member #4215 Joined: Wed Nov 16 2011, 09:45PM
Watch out with high voltage please... sparks are about 25mm. And they hurt. It is unwise to touch sparks even if they are not harmful. Even high frequency voltages are dangerous.
I would say that if frequency were higher you would get more sparks per second. Otherwise you divide mains frequency.
Platinum
Thu Jan 05 2012, 05:28AM
I'm experiences with arcs now anyway I was being careless...when I shouldn't have been ¬¬
Avi
Thu Jan 05 2012, 10:06AM
I don't think you can connect a multiplier to a multiplier since its already DC after the first one. Or did i miss something?
And I've never seen a flyback with an internal multiplier where its input has been accessible
Platinum
Thu Jan 05 2012, 06:11PM
Yes it's on one of the pins on the bottom, if they but the multiplier inside whats the point of having no connection.
