  • Guests: 87
IAmSpock (18)
01/29 IAmSpock (18)
01/30 Ian (37)
01/30 Lucas (40)
Quick IR Camera...
Inducktion
Sat Dec 31 2011, 12:26AM Print
Eh, I was bored today, and I knew my little sister had her old camera lying around.
I had some 80 mW IR LEDs also hanging around, so I got to work.
I removed the IR filter, which was really really easy to do. Took out the 8 or so screws from the camera, popped the front of the camera off, and removed the lens assembly... Then I just pushed the filter right out!
After that I got to work putting the LED assembly together, which was put together using a little perfboard, and 1 3.8 ohm resistor. It's powered off of two AA batteries, and overall, is pretty bright, with 8 LEDs total. It draws 800 mA.
Video:
My apologizes for my little sisters obnoxiousness. :P
Sat Dec 31 2011, 12:28AM
How well does it work at night outside, and what effective range is there?
Inducktion
Sat Dec 31 2011, 01:53AM
I'd say, to see things clearly probably around 6 ft or so. Around 8 ft the brightness really drops off.
After all, it's only 640 mW of IR.
