  • Guests: 66
SiC Schottky Diodes
Inducktion
Fri Dec 30 2011, 07:58PM Print
Hey all. I recently got some of these as a result of ST's sampling program, and was wondering if anyone else had a chance to use SiC technology yet?
I could try to run tests or something with them if anyone would like me to. Their voltage drop is a bit high, though compared to normal Schottky diodes; It's around 1.6 volts at 10 amps.
No recovery time, so no ringing issues. It's pretty neat. I wonder if they'll start using them as the diodes in half bridges to get rid of the recovery time issues that occasionally happen (and occasionally destroys the mosfets/diodes)...
Fri Dec 30 2011, 08:42PM
That's really cool.
I am holding a SiC photodiode that is sensitive to ultraviolet light, and intrinsically blind to visible light.
They are billed as very robust monitors, for example of UV sources that cure ink at newspaper-press speed.
Bought it a few months ago, and hope to actually un-bag and test it before the year is over. frown
Fri Dec 30 2011, 09:01PM
Last time I looked, SiC diodes were very expensive, and while they have no recovery charge, they do have quite a high junction capacitance that causes ringing just the same.
If I were building a large boost PFC with 750V output for a DRSSTC, I'd surely look into them for the boost diode. That's the most demanding application for a diode I could ever think of. It's not exactly a picnic for the MOSFET or IGBT either.
Pinky's Brain
Fri Dec 30 2011, 09:19PM
Capacitance might ring, but at least it doesn't cut off a couple of ampere of current in under a nanosecond ... which something like a 1n4007 is capable of.
Sat Dec 31 2011, 05:08PM
Yes, which is why we don't use 1N4007s for high speed rectification, we use diodes with fast and soft recovery instead.
When you compare the SiC Schottky with the latest generation of ultrafast silicon diodes, the advantage isn't nearly as great as you'd think.
Inducktion
Sat Dec 31 2011, 06:12PM
I know, I was rather disappointed in the advantages and disadvantages...
I was really hoping for SiC to be the next greatest and latest thing.
Pinky's Brain
Sat Dec 31 2011, 06:36PM
They'd be nice for a very high frequency multiplier, also unaffordable.
2Spoons
Sun Jan 01 2012, 07:59PM
The strength of SiC is operating temperature. Max die temp is something like 600C, IIRC (vs ~140 for Si). Great for harsh environments, or if you need to handle a lot of power in a small package.
Fri Jan 13 2012, 12:00AM
I thought they were radiation hardended too fro space-flight apps.
