  • Guests: 54
Building a simple 10X probe
Fulmen
Fri Dec 30 2011, 07:13PM Print
Fulmen Registered Member #3883 Joined: Fri May 13 2011, 06:30PM
Since I've already fried one channel on my scope I figured I should make a simple 10X probe.
The scope has an impedance of 1Mohm and a voltage rating of 250V, making a voltage divider for this is simple enough. But what about some surge protection? With a maximum input of 2,5KV a spark gap before the divider should work, right? But what about something like this:
1325271913 3883 FT0 10x Probe
Can diodes break down fast enough and conduct reliably enough to give any real surge protection? The last zeners would be a backup in case the diodes fail, perhaps those would be enough? This design would limit the input to appr 1KV, more than enough for my work and leaving me with a generous safety margin.
Here's the probe I'm making:
Probe
Fri Dec 30 2011, 08:11PM
im thinking a DIY spark gap would be erratic and not of much use, unless you mean the glass cased ones, no one uses those to often. (gas tube surge arrestors)
better would be a bi-directional TVS at the probe-output, scope-input location. their self capacitcene is negligible, speed is fast and there meant for clamping voltage surges at very high currents.
i wouldnt waste your time with zeners in measurement circuits, they're noisy little cowards.
Fulmen
Fri Dec 30 2011, 09:00PM
A bi-directional TVS diode seems like the perfect solution, I didn't even know they existed. Looks like they're more or less a special version of a zener, right?
Guess I have to find a couple of those.
As for zeners, will they really produce much noise below the breakdown voltage?
Fri Dec 30 2011, 09:19PM
Fulmen wrote ...
they're silicon doping is different, and they function on some different principles.
use mouser.com i think they ship world wide.
Fulmen wrote ...
thats mostly a current driven condidtion, so im tempted to say below breakdown your fine. however you shoul connect one to a scope and see... also Zeners change thier capacitence sort of with varying signal. so id really study zeners carfully, or just use TVS's.
based on your schematic i dont see any attempt to include the capacitence of the scope input, nor any frequency dependent effects... ???
Fulmen
Fri Dec 30 2011, 10:03PM
Patrick wrote ...
Yeah, I was planning on scoping things first to see how it behaves. Pretty much academic now really, since I have to order anyhow I'd might as well order TVS's.
That's because I don't have the first clue how to do that tongue
I've tried the divider, albeit only at 1KHz low voltage, and it seemed to perform fine. But I'd be happy to learn more, if there is a thread that describes this please let me know.
Fri Dec 30 2011, 10:22PM
Fulmen wrote ...
it took me 3+ years to figure it all out.... -> Link2 and Link2
honestly, i think you should buy a normal probe then add a TVS, that way youll get real resistance wire coax for the cord.
Fulmen
Fri Dec 30 2011, 11:04PM
Patrick wrote ...
That's quitter-talk. Me, I'd rather build a 100$ POS than buy the real thing for half the price. Besides, what do I do with this then:
1325286133 3883 FT131210 Probe
Only thing left is to drill&tap the hole for the ground lead and anodize the outer tube. I'm thinking either cherry red or a cool blue.
I'll start reading up on the links you provided, hopefully my brain won't melt within 5 minutes.
Sat Dec 31 2011, 12:11AM
Fulmen wrote ...
... Me, I'd rather build a 100$ POS than buy the real thing for half the price.
i suspect your reasoning may be faulty here...
Also, 16 USD, for two... better than what youll make for 1,000 USD.
Fulmen wrote ...
Youll be unconcious and bleeding from the ears, and prolly seizing in 4 minutes...
i ended up in the ER several times, and im the OP.
Fulmen
Sat Dec 31 2011, 12:41AM
Patrick wrote ...
I reject your reality and substitute my own.
I know it's not cost efficient to make these things myself, but I had some free time and was looking for something to make. Besides, this is so much more educational than buying, I'd never learned about the TVS's if not for this thread.
Great, haven't had one of those since last time I tried reading up on quantum physics.
Sat Dec 31 2011, 05:44AM
ill see your Adam Savage and raise you one Greg Gutfeld....
and yes you can learn much more by building and doing than by sitting in a class room.
