  • Guests: 55
Bifilar Secondary question
Matt Edwards
Fri Dec 30 2011, 06:06AM Print
Matt Edwards Registered Member #2838 Joined: Fri Apr 30 2010, 07:55PM
Hello, I've been searching online... And I cannot seem to find any info for my question... Despite the fact that I am certain that someone has tried this...
Has anyone wound a 'traditional' secondary "Tall PVC form" (example: 4"x18") as a bifilar style coil?
I would love to see any info that anyone may have...
Sun Jan 01 2012, 02:16PM
No answer for a while so I thought I'd pitch in,
I see no advantage to making a bi-filar coil as opposed to mono-filar
as for the same amount of copper (cost)
a single wire 1.414 times the diameter of the bi-filar wire would have about the same resistance but be 71% of the length of the bi-filar coil for the same number of turns,
so self-inductance would be higher (higher L/R is good)
In theory a spaced winding (e.g. space between turns = wire diameter)
(I wound one wire bi-filar with a nylon fishing line of about the same diameter)
gives a higher 'Q' coil hence the possibility of higher voltages, but for a TC where the desired arcs/sparks heavily load the secondary there's not much to be gained and the higher resistance
(e.g. compared to the same coil but with twice the diameter copper and no space)
would result in more power going to heat the secondary rather than the arcs.
ALSO
compare winding say 1000 bi-filar turns of 0.2mm diameter copper wire
to 1000 turns of 0.4mm diameter copper wire.
Sun Jan 01 2012, 03:20PM
I think this might have advantage in high-Q tank circuit Tesla systems (such as VTTC, DRSSTC) in that it could reduce secondary heating due to eddy current losses. From my previous research, eddy current losses may be the main contributor to secondary coil heating in the mentioned coil types.
Matt Edwards
Sun Jan 01 2012, 05:16PM
Thank you gentlemen. I appreciate your input. Gives me a few more questions to investigate.
