  • Guests: 60
What can I do with a million flash boards?
Tetris
Thu Dec 29 2011, 11:08PM Print
I keep collecting them and breaking them, and there are tens of them lying around my room. What can I do with them? I've made a simple taser with one *and lost it somewhere* already, but is there anything I can do with the rest of the circuit or the caps? Can I make a coilgun with the caps and if so, what else do I need? I have very limited supplies and there isn't much else I can do with as far as HV goes because of the difficulty of getting parts through parents (Dad doesn't want me to get a job). So is there anything I can do with them? I go to CVS at least once a week or so, and I get 6-8 boards in each trip I am there, so if I need more boards, I can get them, but I want to do something with all of them. I have about 40 more locked away in the attic but I probably won't touch those for years because its in my "Decade Box" which I vowed not to open for 10 years and it contains the rest of my junk. Anyways, anyone have an idea? I want to post SOMETHING in the projects section... I'm not a HV experimentor until I make something that actually works the way it should...
EDIT: As I was changing my clothes, I swiped my towel off of my bed, knocking over a flash board (fully charged) onto my wet foot. Ow.
Platinum
Thu Dec 29 2011, 11:15PM
I wish I could get my hands on that much stuff, in the last year I got 1 camera flash.
Bjørn
Thu Dec 29 2011, 11:27PM
You only need to add a plastic tube and wire and you have a working coil gun. Link2
I suggest that you stay with a single capacitor for your first three coil guns. Just make something that works and is safe, then you figure out how to improve the next one.
Platinum
Thu Dec 29 2011, 11:31PM
I have a 420v 1000uF+ yet it is badly inefficient, maily I do not have an SCR, and no plastic barrel (eddy currents ¬¬) yet the metal barrel I have has a bolt on the end which reminds me of a AI's L96.
Thu Dec 29 2011, 11:56PM
You could collect the electrolytic capacitors and make an array like mine;
Top view
1325201854 162 FT131162 80u4kvtop
Bottom view
1325201960 162 FT131162 80u4kvbottom
12 rows of (8x 120uF with 2 series 5W 160V series zener diodes for 320V/row)
Result; 80 uF 3.8kV .. 590 very scary Joules Easily charged with a flyback
Probably Lethal - hardly any use!
(anyone want it for p&p and no liabilities of any kind?)
Platinum
Fri Dec 30 2011, 12:00AM
How do you get so many?
Fri Dec 30 2011, 12:12AM
i dont know how he does, but he sent me a huge load of those little ones (i think i counter 204 thanks :)
(Damn i need to use some of the things you sent me :/
Jeff H
Fri Dec 30 2011, 01:44AM
Jeff H Registered Member #4298 Joined: Thu Dec 29 2011, 09:42PM
Sulaiman wrote ...
Top view
Bottom view
That's one heck of a bank!
Tetris
Fri Dec 30 2011, 04:47AM
Platinum wrote ...
CVS people are nice esp. if you've known them for years.
Alex M
Fri Dec 30 2011, 12:54PM
Salvage half a dozen of the capacitors and xenon flash tubes, then bin the rest.
