  • Guests: 55
I tried to make a ZVS from junk.
Platinum
Tue Dec 27 2011, 12:44AM Print
I did try to make a ZVS from junk, it's not working though, for the FET's I'm using (Link2
And I'm using some random 12v zenners and 2 1n4007 diodes. and I couldn't get 10k's so I have 15k's on hand.
Marko
Tue Dec 27 2011, 01:04AM
Hi
Oddly your datasheet link returns results for LM324, I assume your mosfet is 21N50 though.
To spare us of all speculation, could you please post a single detailed picture of what you've made? The help would be tremendous.
Marko
Platinum
Tue Dec 27 2011, 01:55AM
Yes I got the mosfets from a PSU, I also have 13nc50?somthing's
Sorry I do not have a very good camera it also won't focus to macro.
Sorry this is the best, I used solder is it's very easy to construct, and all the solder is 0v.
Link2,yiJbT,aZ8eV#0
Inducktion
Tue Dec 27 2011, 02:13AM
Eh..... I can't understand what's going on there. Make the connections MUCH smaller; You don't need the solder leads between the fets. You'll also need a heatsink. And the two "470" ohm resistors should be similar. You're using two different ones there. They don't necessarily need to be 470, though, anywhere from 300 to 1k will work.
Platinum
Tue Dec 27 2011, 02:41AM
Dr. Duck wrote ...
Sorry it tried to make it from junk, and yes sorry about making the leads to long. I have rearranged the resistors, and I'm using two 470ohm ones to replace the two 1k resistors.
When I first made the circuit my PSU, wouldn't short circuit, but I detected that a 12v zenner was connected in reverse, so I put the zenner like the should be and now the PSU short circuits?
Even then there is no output, I wasn't expecting it to work anyway.
Marko
Platinum wrote ...
Link2,yiJbT,aZ8eV#0
Yeah, indeed very confusing and hard to figure out both for you and us. Also, that's not all of it, I suppose you have a flyback and a tank cap connected to it too?
Try this:
Leave out zeners (for 12V runs), 10k resistors (you don't need those at all, ever), and try to find two equal pullup resistors. They don't need to be as big for start, 0.5W is OK and just make sure resistance is somewhere in range from 330 ohms to 1k or whatever.
Later, you can add zeners (just solder them directly between mosfet gate and source, can't be simpler!)
The thing most people miss is that you need a low loss polypropylene tank capacitor, and tend to put everything there which either doesn't work or swells and dies after a while.
Of course, make sure to verify if your mosfets are still working before venturing further.
Marko
PS. Hard to make out on the pic, but are you completely sure you aren't mixing drains and sources on the mosfets?
Platinum
Tue Dec 27 2011, 03:18AM
I think I'am mixing the drains, with sources.
I'm using the schematic.
I just added two new 12v zenners.
Why does the supply short when I turn the ZVS on?
Marko
Tue Dec 27 2011, 03:54AM
Well, something may be wired wrong, or you have already blown mosfets with previous experimentation. If you indeed used car batteries for power they probably died already.
The Lightning Stalker
Tue Dec 27 2011, 04:10AM
The Lightning Stalker Registered Member #4230 Joined: Sat Nov 26 2011, 05:50AM
I've blown MOSFETs before by just touching the gate lead with my finger. Are you sure the MOSFETs are good? If you have a multimeter with a diode test function, I'd test the diodes as well. With junk parts you never know what is good and what is blown.
Platinum
Tue Dec 27 2011, 04:17AM
Yes I've rested the MOSFET's and they are OK. Zenners are new and are OK, and diodes are good. Is the power supply mean't to short circuit? Atm, I'm not using batteries, I'm using a 19v 3.45a SMPS.
