  • Guests: 35
01/13 si2030 (62)
Linear motion system for CNC
rp181
Sat Dec 24 2011, 07:59PM Print
I am in the process of designing a CNC gantry, for use with PCB routing (and I hope to expand to paste dispensing and pick and place). Here is an image of the back of the Z gantry:
The floating piece is a NEMA23 mount, it will eventually be on standoffs with a coupler the lead screw. Anyway, my question:
As you can see, I had intended to use pillow blocks in .5" shafts. I noticed I could get rid of those though, and use sleeve bearings in the .5" thick side plates. Will it be worth going for this, as the cost would be quite a bit less, or should I stick with pillow blocks?
Goodchild
Sat Dec 24 2011, 09:45PM
Personally I would stick with the pillow blocks, seems to me if you want to do precision type work like pick and place you are going to want the action as smooth as possible.
rp181
Sun Dec 25 2011, 01:44AM
I was thinking as the pillow blocks are of the same type as bushings, they are not ball bearing. The pillow blocks are frelon lined, and using them on the sides spreads the weight further.
It would save $100 :)
