  • Guests: 44
Spark Gap Frequncy
Seeker
Sat Dec 24 2011, 03:19PM Print
Seeker Registered Member #4105 Joined: Sun Sept 25 2011, 02:27PM
How would you measure the firing rate (frequency) of a static spark gap?
Hazmatt_(The Underdog)
Sat Dec 24 2011, 10:13PM
1. Hall effect sensor near one of the output rails, sense the current/low pass filter into a squaring circuit into a freq. counter
2. Microphone/LPF again/squaring cicruit/freq. counter
3. Strobotach. $$$ I have one of these but not sure it's working properly, it's also dim. Make sure you get one with a Xenon flashlamp.
4. All of the above do not necessarily synchronize with the line, you need to ask yourself if you need firing rate AND to know if you're line synchronized. If the answer is yes to both, then you have to come up with a sync. circuit too.
Herr Zapp
Sun Dec 25 2011, 09:13AM
Seeker -
I can't find links to any of the information at this time, but this question has been previously studied in detail, using both acoustic and optical means to determine the firing rate of TC static spark gaps. As I recall, the firing was found to be rather chaotic, and never remotely achieved the steady break-rate seen in synchronous rotary spark gaps. That's why a typical static spark gap sounds so "ragged", without any discernable tone.
Herr Zapp
Sun Dec 25 2011, 10:22AM
