  • Guests: 57
01/23 GimpyJoe (36)
01/24 OnFire (64)
01/25 Evgenij (60)
High Current Flexable wire
Fri Dec 23 2011, 10:19PM Print
Hi,
where is the best place to buy high current flexable cable?
around 30A - 50A
in england?
thanks,
Tom Williamson
Dr. ISOTOP
Sat Dec 24 2011, 04:34AM
Ebay? 8 AWG subwoofer wire is pretty cheap.
Sat Dec 24 2011, 10:23AM
what about flexable High current calbing for the 32A plugs and such?
Alex M
Wed Jan 04 2012, 03:05PM
Tom Williamson wrote ...
Have you got a wickes store near you? They sell all sorts of cables in my local store.
Usually domestic wiring is all single cored stuff. I guess you could try auto-repair shops as they might have car jumper cables that would be suited for high current.
Or what about paralleling up regular 13 amp flex? Sure it might be messy but if this just for a project then it might be an option.
Alex.
Wed Jan 04 2012, 03:38PM
im building a big 50 odd Amp @ 230v input power unit xD
Chip Fixes
Fri Jan 06 2012, 12:50AM
you can use multiple strands of lower current wire and braid them/twist them together and tie the ends together. Just a thought, I did this for my 750 watt inverter in my car. I have not had a problem
Fri Jan 06 2012, 07:29AM
hmm, what im looking for is professional standard cable, for the big commando sockets
Fri Jan 06 2012, 12:11PM
Something like this?
It's 4 sq.mm 3 core flex cable, rated at 32A. Should be available from B&Q, Wickes etc as it's used for installing electric cookers amongst other things.
You might be able to get 6 or 10mm too if you look harder.
Fri Jan 06 2012, 03:51PM
I cycle past B&Q and maplin on the way to school and back, all their cable is eather inaproppriate for the input or solid core :/
i will look @ Wickes ASAP
Alex M
Fri Jan 06 2012, 03:58PM
Screwfix sell reels of cable Link2
Not sure if there is one near you but there is one within a 10 minute drive from me and they have been useful for the odd electrical item.
