  • Guests: 43
M.A.D. (32)
12/14 M.A.D. (32)
12/15 marko666 (58)
12/16 Will T (16)
PVC pipe for Secondary Coil Form
zzz_julian_zzz
Thu Dec 22 2011, 08:23AM Print
Hi everyone,
Which of these (please see picture attached) is the best in application for DRSSTC, I know that the orange one is the most common of them all, and the black one has a carbon in it. I don't know the blue one, which is commonly used in water pipes.
Also, available here in my place is only the blue pipe.. I am planning to build a 2 foot x 6 inches secondary coil form with 30 awg.
what are the possible problems I can encounter if I am to use the blue one?
Inputs please, =) Thanks in advance.
1324542193 3964 FT0 Blackpvc
1324542194 3964 FT0 Orangepvc
1324542194 3964 FT0 Bluepvc
Forty
Fri Dec 23 2011, 03:54PM
Well I guess the worst that could happen is that a pigment in the blue one causes it to conduct at a lower voltage than usual, but i doubt that will really happen.
You should be all right with any color besides black or (maybe) dark grey.
Fri Dec 23 2011, 04:06PM
Since the blue one is for drinking water I'd expect no metalic elements
so it is probably best.
It may be PLE which has much lower dielectric loss than pvc but is softer.
zzz_julian_zzz
Fri Jan 06 2012, 05:02AM
thank you for the inputs.
