  • Guests: 42
J. Aaron Holmes (50)
Lukasz Sterczewski (36)
Coileone (40)
Acoustic voltmeter
Alfons
Fri Feb 17 2006, 10:06PM Print
Alfons Registered Member #134 Joined: Fri Feb 10 2006, 10:44PM
Hi,
I recently found some schematics to build a very simple acoustic voltmeter. It's basically a device built around two BC547 transistors which 'converts voltage to sound'. Doing that, you can hear the voltage, and, according to the author of the article (which was covered in Elektor), it's possible - with some training of course - to be able to tell how high the voltage is, which waveform it has etc... just by listening.
Has anyone got any experience with such a device? I'll probably build one soon, but I am not in the mood right now tongue
Madgyver
Fri Feb 17 2006, 10:34PM
Well, it is actually just a VCO, a voltage controlled oscillator. Its a nice starter project und can be handy if you don't have much space and you only have to know rhougly what voltage is applied.
Although, they are a nice way to transmit a voltage from point A to B if you have a precise Freq to Voltage converter. Better then your ears that is.
Carbon_Rod
Fri Feb 17 2006, 11:08PM
This is fun too (free):
"Oscilloscope for Windows is a Windows application that converts your PC into a powerful dual-trace oscilloscope. Oscilloscope uses your PC's sound card as an Analog-to-Digital Converter (ADC) to digitize any input waveform (speech, music, electric signal, etc.) and then presents it on the monitor in real time, allowing the user to control the display in the same way as on a conventional "standalone" scope, for example change gain, timebase or plot Lissajous patterns." ( Link2 )
2914 and 2915 level LED level chips are a classic too,
Cheers,
ragnar
Fri Feb 17 2006, 11:30PM
Fun too, and free, if you can trust yourself not to connect anything too nasty to your soundcard, and don't mind low frequency...
Calls for ADC and optoisolator, hehehe
Alfons
Fri Feb 17 2006, 11:41PM
Indeed; I once tried that winscope-thing and fried a (very old) sound card frown (It was my own fault, though, I connected a 21V AC transformer directly to the thing cheesey cheesey ; yeah, those were the old days shades )
Bjørn
Sat Feb 18 2006, 02:03AM
The idea is very useful because you can hear things that are impossible to see on a regular oscilloscope. I have several times debugged strange problems by listening to signals that looked perfect but had regular distortions that were audible.
Sat Feb 18 2006, 02:45AM
Bjørn Bæverfjord wrote ...
This probably do to the fact that those regular distortions occurred at a frequency interval other than that being triggered.
If you were monitoring a 100kHz signal, for example, you would never be able to "see" a distortion with a rep rate of say 800Hz, etc...
Bjørn
Sat Feb 18 2006, 04:27AM
Also low amplitudes, small changes in frequency and signals buried in noise are much easier to detect my ear than by eye.
Carbon_Rod
Sat Feb 18 2006, 04:59AM
Dude you must be able to hear Sub-sonic to pick up those AFs.
Or a pakaderm...?
=D
Cheers,
(Spectrum Analyzers are pretty good.. Here is a pic of a DTMF tones.)
1140238784 65 FT1307 Sp1
Alfons
Sun Feb 19 2006, 05:57PM
Or a pakaderm...?
What's a pakaderm?
Seems cool. I'll build one soon.
