  • Guests: 45
RoV IW3IPD (63)
01/13 si2030 (62)
Wiki Troubles
Part Scavenger
Sat Jul 15 2006, 03:29AM Print
I've just got into editing the HVWiki. I've never done anything but read one before yesterday.
Anyhow, I've been working on the LC oscillator page because it was looking sad and empty. frown I drew some pictures for the page and uploaded/inserted them. however, I can't get them to follow my text very well and it all looks like crap. The edit buttons are all in the wrong place too. Please help, what'd I do? I'd like to space out the text so that it works with the pictures.
Thanks
-Part Scavenger shades
Opps! A Link2 would be helpful...
Bjørn
Sat Jul 15 2006, 04:05AM
I did a couple of tiny changes to make it slightly better. Do not worry too much about how it looks, worry about the content. You or someone else will find a good solution sooner or later.
The simplest way to learn is to find somewhere that looks like you want it to look, then examine the code to see how it is done. In many cases it is not possible to get it exactly like you want. This is because you should put all your effort into good content and not waste a lot of time on style.
One solution in your case might be to make the thumbnails smaller so they are not taller than the block of text they belong to.
Sat Jul 15 2006, 05:14AM
They look great to me wink
I would like to request that you put in some info about how 'real' lc circuits work (ie, modeling them as a lrc circuit), as that is how we need to think of them for a lot of purposes... You kind of mentioned it with the little blurb about Q, but it needs more. IMHO
Thanks!
I would put in what little I know, but I hope that someone knows more about it might be able to do a better job...
Simon
Sun Jul 16 2006, 05:00AM
Looks good to me, too. Not so sad and empty.
I added a little on damping.
wrote ...
I think this is good advice. Do what you can do and feel like doing.
It would be handy to just have someone draw some decent schematics for some of the pages, for example.
Try here for inspiration. mistrust
Hazmatt_(The Underdog)
Sun Jul 16 2006, 08:58AM
Things aren't turning out exactly as I had hoped either. I'm haveing troubles getting spaces between expressions in the math commands. And I don't really care what is said...I TRIED ALL OF THEM! It just doesn't handle text the same as it does under the math commands, and I can't get any spacing to work.
Looking at code, yes that does help a lot. I was doing that for a while and I printed out a lot of commands.
Just do what you think is right and put in effort.
Bjørn
Sun Jul 16 2006, 10:38AM
You could try to span the whole line in a single set of math tags and use \quad or \qquad. That should work fine unless you want normal text in there too.
Sun Jul 16 2006, 06:58PM
\quad and \qquad gave an enormous gap such that half of my preview page was empty space. I couldn't get those to work. There is some formatting that has to be done differently in math then text and im not familiar enough with it yet.
Simon
Mon Jul 17 2006, 12:49AM
As a tip, when you're typing and come to a word that has its own page, like "energy", put it in double square brackets like [[energy]]. That'll make it a link to that page; an easy way to tie the wiki together.
There's no need to do it more than once in a section, of course. Just the first instance is enough.
BTW, the maths formatter has its own ideas on everything. It's possible to fight it to make things look nice but I generally don't stress all that much about it.
Part Scavenger
Mon Jul 17 2006, 01:26AM
Thanks guys. I really liked drawing the pictures more than anything, maybe I'll do some more of that when I get around to it. Feel free to add anything you like, it's a Wiki after all!
Simon
Mon Jul 17 2006, 02:38AM
Part Scavenger wrote ...
Excellent! It needs that.
