  • Guests: 55
Projection TV salvage
paris
Sun Dec 18 2011, 08:58PM Print
paris Registered Member #3042 Joined: Wed Jul 28 2010, 12:36AM
I ripped a Projection Tv and got 2 gapped cores with 1/16 inch gap .
What can these be used for seeing the gap is so big ? ?
They had litz wire which means it was HF . I cant find any data sheet with these dimensions.
49mm wide , 54mm high , window 37 x 10 mm , centr leg 17.16 x 18.5 high , outter legs 27 mm , gap 1/16". continuity test = open usually ETD 49 25 16
1324241887 3042 FT0 49core
M.A.D.
Mon Dec 19 2011, 02:02AM
M.A.D. Registered Member #4052 Joined: Thu Aug 11 2011, 04:43AM
You could probably take a file to the outside legs and reduce the gap to whatever you want. It would be messy and time consuming though.
paris
Mon Dec 19 2011, 08:05AM
man ! that would be some serious filing , they grind them with god knows what..
I was just wondering if any one has done anything with these. The big gap would be for the saturation I guess or storage.
Also pulled big ugly FBT , anyone find these usefull candidates ? or are they too big ,theres 3 out puts and a mass on the side
1324281886 3042 FT130529 Fbt
