  • Guests: 68
tesla coil primary wire
lokeycmos
Fri Dec 16 2011, 06:15PM Print
lokeycmos Registered Member #2553 Joined: Fri Dec 18 2009, 01:36PM
so im on a really tight budget. im working on my primary coil right now. im probly not going to be able to get copper tubing, which is ideal. im probly goona have to use solid single strand wire. will this affect the performance? what guage should i use? 12 guage is the easiest to find. just looking for your input on this. ty
Gunboat
Fri Dec 16 2011, 11:54PM
Gunboat Registered Member #338 Joined: Thu Mar 23 2006, 12:28PM
I have used stranded wire on a small SGTC with great success,try it and see what happens...you didn't post what size of coil you are building...you can even use aluminum with also..
lokeycmos
Sat Dec 17 2011, 08:01PM
3.5" x 22" SGTC
dude_500
Sun Dec 18 2011, 05:52AM
dude_500 Registered Member #2288 Joined: Wed Aug 12 2009, 10:42PM
Tube is ideal, next up single-conductor solid wire, worst being stranded. All of these being due to skin effect. Tube is best since the inner core is useless, so for the same copper you can get more surface area. Stranded is by far worst, because in order to stay on the outside of the whole conductor, the current has to continually jump from wire to wire, which involves crossing lots of oxidized layers so the high frequency resistance shoots up way faster than any solid conductor would.
teravolt
Mon Dec 19 2011, 02:49AM
if you can find about 10 ft of # 4 it will do fine thats how I started. it may be easyier to find scrap wire than copper tubing. I have even made SGTC primary's with aluminuim tubing and wire wich is a cheaper subtitute
