  • Guests: 62
replace antenna for a ct
tritium
Sun Dec 11 2011, 06:43PM Print
tritium Registered Member #2591 Joined: Fri Jan 01 2010, 11:58AM
hello coilers,
I want to replace the antenna in my pll (class-e) system for a ct on the base of the secondary (see schematic), what do I have to change to do this?
I was thinking of a couple of 5 volt zener and shottky's like steve ward do this in his drsstc.
the reason is that I wan't to place a second coil for stereo sound, so I can't use a antenna anymore.
q2 can I use amidon t50-2 for the job?
fres is about 4.7 mhz
22
M.A.D.
Sun Dec 11 2011, 10:33PM
M.A.D. Registered Member #4052 Joined: Thu Aug 11 2011, 04:43AM
I have seen twin coils ran on an antenna before. They say that the antenna just has to be a lot closser to one of the coils.
tritium
Mon Dec 12 2011, 04:17PM
@ M.A.D. my 2 coils are 1 meter (40 inch) from each other, it is a stereo audio modulated system, 500watt/channel, and I realy hate the antenna, i wan't to make a ct to feed it back to the pll via coax.
thanks anyway cheesey
