  • Guests: 64
Math text book fail.......again
haxor5354
Thu Dec 08 2011, 01:25AM Print
take a look at question 15 part c)
yeah i'd like to see what happens if you stick 100,000,000,000,000,000,000 volts into an op-amp
on thing for sure, it won't output 25v ;)
494
Inducktion
Thu Dec 08 2011, 01:40AM
... I don't understand, what's wrong?
Turkey9
Thu Dec 08 2011, 01:54AM
Are you commenting on how the equation doesn't put a limit on the input or output? They are assuming an ideal op-amp in an attempt to relate math to real life.
magnet18
Thu Dec 08 2011, 02:02AM
those math types... they have no idea how to actually USE it for something tongue
Dr. Slack
Thu Dec 08 2011, 08:19AM
... as well as confusing the students as to the way the term "op-amp" is used today. Once upon a time, when valves were replacing wheels, shafts and discs in analogue computers, operational amplifiers were modules that performed "an operation", so your analogue computer might contain adders, gain blocks, logging amplifiers, to be patched together with 1/4" jack leads.
These days of course, an "op-amp" is just an amplifier with huge gain intended to be tamed with some sort of feedback, and the function they describe would tend to be called a log-amp.
The input may need to be in the order of 10^20 volts, but log() is not well defined. It could be log10, but loge or ln is another possibility. Even if it was log2, the input would still be a bit large for an op-amp (for large values of "a bit").
Hon1nbo
Thu Dec 08 2011, 01:34PM
Dr. Slack wrote ...
mathematical convention is to assume that log x = log [base 10] of x unless a different base is denoted (log base e of x has a special form, "ln x," which is used whenever it is "e")
-Jimmy
AndrewM
Thu Dec 08 2011, 02:45PM
DaJJHman wrote ...
Dr. Slack wrote ...
-Jimmy
This seems to apply in math education but many other fields disagree. I recall a number of physics texts where log is assumed to be natural log. Several computer algebra systems or scripting languages (e.g. matlab) define "log()" as natural log; base ten log is "log10()."
haxor5354
Thu Dec 08 2011, 10:21PM
the answer at the back of the book says its 10^20 volts
Killa-X
Thu Dec 08 2011, 11:11PM
haxor5354 wrote ...
You should demo this to the author of the book...
Thu Dec 08 2011, 11:41PM
It's common for math textbooks to give idealized examples that don't work in the real world.
Even at first grade level:
"Billy had four cookies.
Annie and Sally asked him for two.
How many did Billy have left?"
