  • Guests: 37
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
NST resistance measurements
rulmismo
Tue Dec 06 2011, 09:27PM Print
rulmismo Registered Member #4187 Joined: Fri Nov 04 2011, 08:08PM
Hi, I just checked the windings resistance of my NST of 8kV 60mA 50Hz and got:
1- primary 3 ohms.
2- secondary leg to leg 7.48 kOhms
3- secondary (leg1) to connection named "0": about 227,4 kOhm
4- secondary (leg2) to connection named "0": about 227,4 kOhm
5- connection "0" to primary ground connection: about 224 kOhm.
I was using "0" connection as center point for my Terry filter. I am assuming that this "0" is center point of secondary, but not sure really, and less with this data (I have no schematic of the NST)
I don´t know either what means measure 5
what do you think? should I forget about connectiong "0" to anywhere?
Herr Zapp
Wed Dec 07 2011, 07:31AM
rulmismo -
Can you post a few photos of your NST, showing all the "connections"?
Herr Zapp
Wed Dec 07 2011, 11:36AM
The ground fault detection circuit connects between the "0" and the primary ground. For Tesla coil use, the GFI should be removed, as it will trip spuriously if not self-destruct. Then "0" and primary ground should be connected together, and also to the case.
At least, this is what's inside my Italian "FART" brand resin potted NST. (Love the name smile )
rulmismo
Wed Dec 07 2011, 01:57PM
Thanks, actually mine is also of that "FART" brand smile
measuring from leg1/leg2 to mains gnd I get half secondary resistance, so it seems that secondary center point is connected to mains gnd actually.
I will follow Steve´s advice and will connect together "0" and mains gnd terminals to case.
With usual Terry filter there is a safety gap mid-point connected to NST mid point.
With my NST I am connecting this mid-gap point to mains GND.
Do you think that makes sense or better just use a safety gap from HV leg to leg? (without mid-gap point to NST)
Regards!
