  • Guests: 48
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
ZVS Inductor
Thu Dec 01 2011, 11:24PM Print
Hi,
what torroid do i need for a ZVS driver,
im planning to buy off ebay but im not sure what one
thanks
Fri Dec 02 2011, 01:34PM
something like this Link2
or if you're going to 100's khz this Link2
what dc voltage, current and frequency are you aiming for?
Fri Dec 02 2011, 04:53PM
as much power as i can get my hands on without destroying the circuit
...hey ive got a nice 300Kv Pylon closeish to my house....
Forty
Fri Dec 02 2011, 05:20PM
the large toroid cores from computer power supplies always seem to work fine for me. If you're going to be running it at a high frequency (ie. low L and low C) you might want to consider using a ferrite core with litz windings. coilcraft will sample you inductors for free if you know the general specs you need.
technology man
Fri Dec 02 2011, 09:43PM
technology man Registered Member #4193 Joined: Mon Nov 07 2011, 11:21AM
I´ve use a core from a pc-powersupply.
Its yellow and i made 40 windings around the core.
Tue Dec 20 2011, 02:09PM
will the yellow torriod cored also work for a Fullbridge GDT with CAT5 Cable (filer windings)
Electra
Tue Dec 20 2011, 03:22PM
For the Toriods for the inductor in the dc supply, you would typically use iron power of some kind.
Gate drive transformers like those used in bridges, far as I know are best with ferrite micrometals start with the part no FT- I have also used the kind intended for interference applications unpainted dark gray about 19mm in dia, although the exact material was unknown.
Tue Dec 20 2011, 04:09PM
ah thanks
