  • Guests: 60
RoV IW3IPD (63)
01/12 RoV IW3IPD (63)
PS3 400W PSU flyback driver.
Platinum
Tue Nov 29 2011, 08:44PM Print
Sorry to make a new thread but I'm happy as I completed the driver. All I did to make this was solder outputs of the un rectified PSU output (12v 32A) and those wires come through the PSU casing and go to a wire connector.
Here is a video of the output. If I had to estimate the arc goes 4"+
Inducktion
Tue Nov 29 2011, 10:07PM
Wow, those are some pretty amazing arcs. Nicely done.
Platinum
Tue Nov 29 2011, 10:24PM
One problem is that, the flyback arc is not as high current anymore, is there any reason for this? the voltage is very high but the current has dropper.
And it seems that the flyback likes a big air gap in it's ferrite.
I think I know what caused the current to drop, the HV from the flyback came back into the circuit and some resistors on the surface and maybe more stuff has overvolted and fried, how do I stop HV coming back into the circuit?
Daedronus
Tue Nov 29 2011, 10:43PM
basically you are feeding a square wave into the transformer.
This is the same as using a push/pull or half bridge or full bridge driver.
The low current is probably because of the low duty cycle. the psu is probably trying to regulate the voltage, and since there is not much power consumed from the rectified 12V side it is running at low duty cycle.
Moral of the story, a full bridge is (one of) the best transformer driver.
Learn how to make your own bull bridge driver so you can have it run at whatever duty cycle you want.
Platinum
Tue Nov 29 2011, 11:15PM
The HV going back into the circuit actually destroyed it, tjis was my only 12V supply :(
Ohh well.
Alex M
Wed Nov 30 2011, 06:51AM
Dude that was amazing!
Hopefully the PSU was not an expensive one. Might I suggest lead acid battery's for powering things like this, they can take some abuse and are not very expensive if you go to the right place's to buy them.
Ash Small
Wed Nov 30 2011, 08:09AM
Alex1M6 wrote ...
Lead acid batteries wouldn't work here if I've read the thread correctly.
All Platinum has done is by-passed the rectifier on the PSU output, and fed the un-rectified PSU output straight into a flyback, if I understand this correctly. (possibly with a series capacitor as well)
(at least, that's what I think he has done, I'm going to have to try this myself)
Platinum
Wed Nov 30 2011, 12:50PM
Ash Small wrote ...
Alex1M6 wrote ...
You are exactly correct, I had the PSU from a old 60GB PlayStation3, I just used a multimeter and checked the voltages on the secondary and directly soldered two wires on the output, and then fed that High Frequency into the flyback.
I've also done this with PC SMPS's, even wallworts like router PSU's, chargers, anything using ferrite cores. I couldn't stop the High Voltage coming back onto the circuit and some resistors got fried, and output dropper badly then nothing. In future how do I stop HV coming back to the circuit?
You can't power this off batteries because it's a very complex circuit inside, it uses mains.
Inducktion
Wed Nov 30 2011, 04:06PM
You could probably try to add a filter of some sort, a snubber. (they block and prevent voltage spikes)
It can consist of a few different things. The easiest is just a resistor and a capacitor.
Two zener diode and resistors would work too, just connect them in antiseries across the primary wires. (cathodes both facing outwards across the primary leads) You just need to get zener diodes that are higher voltage than the square wave you're feeding your flyback.
Platinum
Wed Nov 30 2011, 04:36PM
OK Thanks man!
I wish I could get old PSU SMPS's from my tip but they don't allow anything to be taken :(
Because I don't have money to buy these things new.
