  • Guests: 39
Cardboard Tesla coil?
Mon Nov 28 2011, 09:09PM Print
Hi all.
The availability of cardboard tubes from the inner pieces of some packaging (Christmas and all that) got me thinking.
Could one of these be coated inside and out with a suitable HV varnish such as Krylon triple thick glaze while spinning and then once dried be used as a TC former?
Not sure but I think it would be fairly lossy, however when properly dried not so much.
Also, why can't I modulate the input to an OBIT (designed to run at 50Hz) to energise the resonant circuit directly?
The plan here is to use relatively cheap 240V rated parts such as a pair of MOSFETs in series with the neutral side of the OBIT
so that I can run the coil at resonance i.e. 240V 50Hz and 31.2 kHz say.
Thanks!
-A
Mon Nov 28 2011, 09:49PM
I have used cardboard TC formers previously and they worked well. I didn't coat them or anything. They were fine in a room environment, but would probably soak up moisture when allowed to.
Marko
Tue Nov 29 2011, 07:11AM
Well, think about it; OBIT's huge parasitic capacitance and inductance will make it's own resonant frequency far lower than of any practical TC, even if the losses in iron at 30kHz weren't extreme. Base driving with ferrite transformers has been attempted but failed miserably for the same reason.
On topic, many people including Steve Ward have used cardboard tubes as their secondary forms with great succes, though they may indeed be prone to absorbing moisture unless they are impregnated with varnish or epoxy first.
PVC tubes are cheap and easy to wind on though, and probably by far best for all pulsed coils which won't heat up significantly during operation... and for others, I prefer fiberglass tubes anyway ;)
Marko
Tue Nov 29 2011, 08:06AM
OK, it seemed like a good idea...
What about modulating the output side using a suitably rated fluorescent tube with a coil wound around the centre as a magnetic arc pinch-off?
Not sure if this has even been tried, it seems feasible.
Sort of like a magnetic amplifier but with plasma.
Would probably work best with a xenon flash bulb as this is designed to take enormous currents.
-A
TeslaJunky
Tue Nov 29 2011, 09:00AM
TeslaJunky Registered Member #3037 Joined: Mon Jul 26 2010, 06:42PM
The losses with cardboard are really not noticeable as long as you varnish the tube as best as you can. Also, it might help to dry it out with a blow dryer or by leaving it out in the sun, as they can absorb moisture. For my large 12" coil I used sonotube, which is similar to cardboard. I dried it out thoroughly and varnished the cardboard 3 separate times.
