  • Guests: 72
01/23 GimpyJoe (36)
01/24 OnFire (64)
01/25 Evgenij (60)
50 watt plus audio output transformer
Nah
Mon Nov 28 2011, 03:07AM Print
Nah Registered Member #3567 Joined: Mon Jan 03 2011, 10:49PM
Hi!
I need a 50 watt plus audip output transformer with a primary with a impendance of 8-16 ohms and a secondary of 2-2.5k for my flame speaker.
Thanks!
Paul
Yeah, thanks! I had one too many the day before...
Mon Nov 28 2011, 03:26AM
Are you sure your primary & secondary specs are for resistance, not impedance?
Resistance sort of implies DC winding resistance, and the ohm values you gave are probably not what you want there.
Impedance is customary when talking about signal transformers.
It's not something you can measure (AC or DC) on an un-loaded transformer.
Impedance -ratio- is the square of the turns ratio (square of the voltage ratio).
Perhaps you can use a tube-audio-output transformer backwards. Link2
Tue Nov 29 2011, 09:44AM
Yes, the original project he is copying used a tube audio output transformer backwards. tongue
Try Antique Electronic Supply, Hammond, Triode Electronics Link2 or Ebay.
