  • Guests: 48
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/17 Madgyver (40)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Simple Pre-amp problem
Experimentonomen
Wed Nov 30 2011, 04:22PM
Link2 <-- this circuit will give you several watts of driving power as it is intended to drive speakers directly, if you can live with 0.3% THD at 20kHz.
Wolfram
Wed Nov 30 2011, 07:42PM
He isn't trying to make an amplifier to drive a speaker, he's trying to test an amplifier he has made for some other purpose with a speaker.
In other words, your amplifier might work perfectly fine, you're just testing it in the wrong way. What sort of circuit will be connected to the output of this amplifier in your audio coil?
Also, that sort of transistor circuit tends to be a bit sensitive to variations in transistor gain, so it's not ideal. Adding a resistor between the transistor emitter and ground will make things a lot better. Just using an op-amp instead is easier to calculate, and even better in most respects.
