  • Guests: 35
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
Simple Pre-amp problem
Alex M
Sun Nov 27 2011, 12:13AM Print
Hello, I am trying to put together a very simple pre-amp circuit that I plan to use to boost the audio signal that will be feed to my plasma speaker driver.
However I cannot seem to get it working correctly. My parts for the new plasma speaker driver have not arrived yet so I connected the output to a small speaker and found that the audio is very quiet and distorted. It sounds much better and louder just directly connecting the MP3 player to the speaker which is not what I want.
All connections have been triple checked and the circuit is how it should be.
Can anyone with knowledge please advise on what I am doing wrong. I would greatly appreciate it.
Thanks.
BTW this circuit is not my own design, it is just one I found on the web but it appears to be a very common design.
Schematic
Sun Nov 27 2011, 03:23AM
This looks like an amplifier for an electret microphone,
not a power amplifier as it requires a load >= 10 kOhm
so it's probably working as designed
it's just that it's not for driving a loudspeaker.
Sun Nov 27 2011, 08:42PM
Alex, your R2 looks much too low. As a rule of thumb your R2 should be equal to R3*hfe.
So stick one or two meg in the R2 position, and see where that gets you. smile
Sun Nov 27 2011, 08:59PM
Seem to recall a very simple circuit using a single 2N7000 with ridiculous gain at frequencies up to 10 kHz.
From memory it used 2*10M resistors to bias the gate and a 0.1 uF capacitor for input coupling.
-A
Newton Brawn
Tue Nov 29 2011, 03:25AM
HI
The output impedance (5~10Kohms) is no matched with the loudspeaker impedance (4 ohms)..
Try to use a small audio tranformer between the autput and the loudspeaker. Zp=5~10 Kohms, Zs=4 ohms
Or use small 230/5V power supply trnsformer
better sound and higher volume
Regards
Alex M
Tue Nov 29 2011, 10:30AM
Thanks for the replies guys, I am going to try your suggestions and see how it fairs.
Regards.
Alex M
Wed Nov 30 2011, 08:02AM
Just tried it with a 1mohm resistor and it sounds even worse.
It is really scratchy and hard to hear now.
Wed Nov 30 2011, 01:23PM
If you are connecting this circuit directly to a loudspeaker, rather than to another stage - as shown in your circuit diagram - there is no way it can work properly. As Sulaiman and Newton Brawn have said, the impedance mismatch is too large - indeed, an 8Ω impedance is not far off being a short across the output.
Alex M
Wed Nov 30 2011, 02:52PM
Proud Mary wrote ...
ok thanks anyway.
BTW what does "impedance mismatch" mean? And doesn't the DC blocking capacitor stop it (the speaker) from being a direct short?
Wed Nov 30 2011, 04:12PM
Alex1M6 wrote ...
ok thanks anyway.
impedance mismatch, analogy: imagine the flow of water through a very small diameter hose (your output) coupled to one of very large diameter (your loudspeaker) Consider how the velocity of the water will change as it moves from the narrow hose into the large one.
Blocking capacitor: yes the capacitor does block DC, but it is the AC component - your audio signal - which is getting shunted to earth through your low impedance loudspeaker for very little effect.
This circuit would work with high impedance headphones - say 2000Ω - but these are usually expensive, and not easy to come by.
