  • Guests: 36
Kapanadze Generator - yes, I know, don't worry.
LD LANGER
Tue Nov 22 2011, 07:17PM Print
LD LANGER Registered Member #3824 Joined: Sun Apr 10 2011, 08:29PM
Hello everyone,
So I'm not going after this saying "OMG Free ENERGIEZ!!1!", I just want to see if anyone can tell me how he does this using conventional methods. They are obviously using more power than they put in, but the method in which they produce it, I cannot figure out.
Anybody have any ideas or seen this type of setup before?
Thanks
Inducktion
Tue Nov 22 2011, 07:31PM
It just looks like resonance to be honest...
LD LANGER
Tue Nov 22 2011, 07:55PM
Yeah, according to the schematic, it appears they are trying to use the potential differences between the two grounds and "tune" their transformer to the resonance of the circulating ground currents..
This seem like a close analysis?
I'm sure most people have seen a setup at least somewhat like this before.
Carbon_Rod
Wed Nov 23 2011, 11:13AM
In some places, it is common to have over 40v DC potential offset from neutral and earth.
However, this device produces a power factor issue with a ground mismatch, and assuredly does not magically produce energy. I would wager the utility meter is clocking more than the floating instrument he used to profile the input. Additionally. even true RMS meters may not be fast enough to adapt to high frequencies, and would give a erroneous reading.
Most of the time these amateur discoveries are made by people who genuinely believe that it is a "new" phenomena. Yet it is often a simple exception of an ideal estimation tool rather than a violation of the underlying equations the simplified derivation is based on.
After a few dozen of these... you begin to lose your sense of humor about them...
This site should have a separate crank-files section...
wink
