  • Guests: 45
01/23 GimpyJoe (36)
01/24 OnFire (64)
01/25 Evgenij (60)
High voltage source needed.
ifryd
Mon Nov 21 2011, 11:09PM Print
ifryd Registered Member #4215 Joined: Wed Nov 16 2011, 09:45PM
Hi
I am looking for high voltage source. I made a search for high voltage transformers but I have to admit it is hard task.
I am searching for a source which could give me at least 10kV and 20mA.
Inducktion
Tue Nov 22 2011, 12:59AM
That should be relatively easy to get with a simple flyback transformer, actually. Just grab one out of a tube television set and you should be set to go. Though, you'll need to make a driver for it.
ifryd
Tue Nov 22 2011, 11:38AM
How much current I will get from flyback transformer? What do you thin about neon transformer and cascading them in series to get higher voltages?
