  • Guests: 79
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/17 Madgyver (40)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Advice needed- HV5522 driving nixies
Fri Mar 23 2012, 08:35AM
I have some of these chips here.
Can you send a copy of the code you used?
Am having a lot of problems getting the I2C to do anything.
tobias
Sat Mar 24 2012, 04:17AM
tobias Registered Member #1956 Joined: Wed Feb 04 2009, 01:22PM
Conundrum, I believe you are mistaken about the interface. The HV5522 I have are not I2C. They are indeed latched shift registers. It works just like the 74HC595, and there are tons of material about this one avaiable online, including code. You just have to 'stack' four of them (8bits) for each HV5522 (32bits).
What is the uC you are using?
Be aware that the HV5522 requires 12V on latch, blank, data and clock inputs. I used mosfets as a level shifter since I am using the Atmega328.
But I was silly enough not to care about getting all the signals inverted. Doing it again, I would follow this:
I am still working on the code. But got first light already!
Sat Mar 24 2012, 12:56PM
Oh.
That ought to explain the problems, thanks!
Wonder if anyone has tried to make a matrix EL display with this and Jeri's EL PCB track idea yet?
Use etched ITO as the front contacts and cover, and heat seal it onto the display.
Idea *2, drill holes through the (thin) PCB then drop a microscopic droplet of dielectric and phosphor onto each hole and pull a vacuum through the panel.
Plus it allows you to do colour if you use highlighter pen ink.
On the whole "MEMS driver" thing, would this have any chance of working for a DLP projector where the driver IC is fried?
The DLP "looks" OK but without the data sheet its going to be a particularly gnarly hack.
I may be able to trace the power lines easily then use DMM to each pin to determine the chances of each line being an address line, data line or clock.
