  • Guests: 52
now thats what i call a arc!
Sun Nov 20 2011, 01:19AM Print
Hi,
have look at this:
largest homemade arc ever seen?
Antonio
Sun Nov 20 2011, 01:50AM
I just see metal burning and a big waste of energy. But it would be interesting to see a three-phases jacob´s ladder.
Platinum
Sun Nov 20 2011, 02:31AM
What's 3 phase?
Inducktion
Sun Nov 20 2011, 02:47AM
3 phase is a type of AC current.
Just three sine waves, all out of phase by a certain degree. 1/3 phase of each.
Sun Nov 20 2011, 09:21AM
For a 3 phase JL see Link2
Bigger homemade arc: Link2
My Jacobs ladder, 1 meter arcs: Link2
Platinum
Sun Nov 20 2011, 11:57AM
So 3 phase has 3 outputs?
doctor electrons
Sun Nov 20 2011, 01:17PM
You could say that. Three phase is power that has three "legs" with their positive and negative
peaks happening at an equal but separate time. Common three phase transformer hookups may
help you understand better. Google three phase delta and three phase wye. Delta is basically
a triangle made up by three coils with the tap points at the three points of the triangle.
There is also a polyphase, that is usually used for electric motors.
Ash Small
Sun Nov 20 2011, 02:02PM
The 240V mains in your house is one phase of the three phase supply.
The three phase is 410V.
These voltages are the 'average voltage', called RMS voltage (root mean square).
If you google it, you will find a much better explanation than I can give here.
Sun Nov 20 2011, 02:09PM
Dr. Kilovolt wrote ...
those are some quite impressive arcs!
i need more money... i must rival!
Tetris
Sun Nov 20 2011, 04:27PM
doctor electrons wrote ...
Which Nikola Tesla invented :3 (polyphase alternating current)
Er... I wouldn't be standing that close to the plasma... also I think you fried your camera.
