  • Guests: 17
Gavin (49)
Froskoy (33)
UnHappy1 (59)
07/17 Eric (53)
07/17 HM_Murdock (53)
07/18 Billybobjoe (35)
QCW Documented
Goodchild
Sat Nov 19 2011, 09:51PM Print
Hello every one, there has been a lot of talk about QCW lately on the forum and lots of question being asked.
I decided to do a nice well documented page on my experience with the QCW on my new web site. As far as I know I was the first to duplicate Steve Ward's results (This is unconfirmed). with the class D bus voltage modultion
Enjoy: Link2
Fell free to ask question. smile
lightlinked
Tue Nov 22 2011, 06:32AM
lightlinked Registered Member #2087 Joined: Tue Apr 21 2009, 08:32AM
Thank you for doing this. Sharing and documenting our research is what makes us a scientific community.
Are you using a PFC boost converter or a rectifier?
Avalanche
Tue Nov 22 2011, 01:16PM
I finally got around to reading it - interesting article, thanks smile
I'm looking forward to seeing how things develop in the QCW world, even if I never get around to trying anything properly myself. The audio modulation should be particularly entertaining, if anyone can find any IGBTs that can cope with the abuse cheesey
Dr. Drone
Tue Nov 22 2011, 03:34PM
shades
Tue Nov 22 2011, 06:04PM
Dr. Spark, you should modulate the plate voltage on your Quadzilla. You could call it QuasiModZilla.
Goodchild
Tue Nov 22 2011, 06:30PM
Thanks for the positive feedback. To answer a couple of question.
No I don't use PFC "yet". I have yet to decided if it would really be worth it to add an extra layer of complexity to this project. Because I can see it know, one 60N60 in the full bridge fails, this shorts the other 60N60 in the half bridge, this puts a dead short on the modulator, shorting all it's 10mF of bus C and kill it, this then puts a short on the PFC and possibility killing it! It's a scary thought, a big domino effect of dead silicon suprised
Audio modulation has already been tried on the QCW by Steve Ward, and the results of very cool! It's just a matter of using only half the audio signal to maintain <50% duty operation.
Man you are going to need one hell of a modulator to do QuadZilla!!!
Gregory
Tue Nov 22 2011, 07:25PM
QuadZilla with a modulator will be a beautiful setup.
Eric,
Maybe you can try some OCD at the buck inverter output, before the output LC filter. One 100A shunt can do the job!
Tue Nov 22 2011, 09:13PM
If Phillip Slawinski's "SSVC" can do this by modulating one 833
Just think what Quadzilla could do with four of them. It would be monstrous, you must do it Dr. Spark!
The QCW and the SSVC are pretty much identical, and the same theory applies.
Goodchild
Tue Nov 22 2011, 10:02PM
Gregory wrote ...
Eric,
Yes I was originally planning on having a LEM100 DC current transducer do the job. But I never got around to adding it. I will most likely implement this in the final design.
Tue Nov 22 2011, 11:18PM
Steve, AFAIK Phillip used a ridiculously high voltage on the plate which surely doesn't help the tubes life. Maybe if you used such a high voltage transformer with a standard doubler and a staccato, you could get similar results...
