  • Guests: 61
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Components under the primary
Sat Nov 19 2011, 07:16PM Print
Hello guys,
do you have any experience with putting the components under a TC primary? Here we're talking mainly about the DRSSTC and VTTC, where the induced voltage per turn is very high.
What do you think would be the safe distance for things such as heatsinks or metal cases, so they don't heat up from the induced eddy currents? And what about control circuit boards working with signal-level voltages?
technology man
Sat Nov 19 2011, 07:30PM
technology man Registered Member #4193 Joined: Mon Nov 07 2011, 11:21AM
I have put the electronics under the prim and after, the sparcs was smaller.
Put the electronics in a metall case, und use a wire to earth or ground.
