  • Guests: 54
J. Aaron Holmes (50)
Lukasz Sterczewski (36)
Coileone (40)
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Plasma speaker question
HDF49
Wed Nov 16 2011, 06:01PM Print
HDF49 Registered Member #977 Joined: Thu Aug 30 2007, 06:57PM
What frequency audio can a plasma speaker operate at? Obviously not the frequency of the spark, but the frequency of the audio it can produce.
Inducktion
Wed Nov 16 2011, 07:31PM
It's usually in the higher frequency range, as far as I know. Some plasma speakers can do decent bass, though.
Alex M
Wed Nov 30 2011, 06:53AM
Well the frequency of the arc is the carrier frequency which is usually set above the hearing range, the sound is usually made via pulse width modulation.
doctor electrons
Wed Nov 30 2011, 10:29PM
doctor electrons Registered Member #2390 Joined: Sat Sept 26 2009, 02:04PM
Generally above 20khz because at or below 20khz you would hear noise from the arc.
Some of the nicer units run at 4mhz with the arc almost silent.
The only audio that you can hear is 20hz-20khz so the plasma speaker is useless outside of that range
but i believe they are capable of producing audio outside that range.
Chip Fixes
Wed Nov 30 2011, 11:08PM
Chip Fixes Registered Member #3781 Joined: Sat Mar 26 2011, 02:25AM
It usually can't produce any music below 1khz
