  • Guests: 43
3D resin printed TC?
Wed Nov 16 2011, 05:53AM Print
Hi all.
The recent Hackaday activity on laser 3-D printers got me thinking.
How feasible is a fully 3D printed Tesla Coil?
i.e. print the secondary "on the fly" with wire embedded in the plastic.
Once done, lift finished coil out and rinse with solvents etc to remove any
uncured monomer and test.
Sound feasible?
-A
Wed Nov 16 2011, 04:21PM
Using my reprap (FDM type 3d printer) I have printed a few parts for my upcoming DRSSTC. Not the secondary though. Only end caps for the secondary and possibly primary supports.
I believe the reprap project is still working on embedding wires in printed parts. Its more difficult then one would expect.
Tetris
Wed Nov 16 2011, 09:18PM
soon... because nothing is impossible. sone day it will happen
Ocean Waves
Tue Nov 22 2011, 08:18PM
Ocean Waves Registered Member #4181 Joined: Thu Nov 03 2011, 02:39PM
I want a 3d printer that prints metal parts, I often wounder if you could use a mig welder on an xy table, to make crude stuff.
the printers avaible use metal powders and a co2 laser in a vacuum chamber, they can even print fine threaded holes and studs from what i have read, but at the price of 1 million dollars i don't think i will ever have one it would be preaty cool to just print out a bolt and nut you need......LoL
Goodchild
Tue Nov 22 2011, 10:06PM
What we need is a printer that prints on the atomic level! This would also get past the problem of strength. As you could print out pre-tempered bolts.
Hell you could just print out a carbon nano tube bolt... shades
Dr. Drone
Wed Nov 23 2011, 01:35AM
shades
Ash Small
Wed Nov 23 2011, 10:56AM
Can you use a cheap(ish) one to print with wax?
You could then use a 'lost wax' casting process (vacuum induction casting?) to produce the part required.
2Spoons
Fri Nov 25 2011, 01:54AM
I'd say it would be a rather expensive way to make a coil of wire!
Fri Nov 25 2011, 07:36AM
Ash Small wrote ...
You can burn out the PLA and ABS plastics which most FDM based 3d printers (reprap and makerbot) print with.
