  • Guests: 35
Mycologist (34)
Some_Polak (31)
brandon3055 (31)
10/15 OiD (38)
10/15 jolty (50)
10/15 Baran (29)
Ipod touch went through the washing machine
Inducktion
Sun Nov 13 2011, 05:33PM Print
My 1st gen ipod touch recently went through the washing machine.... (don't yell, I know, I should've checked my pockets)
I waited around 24 hours, with the ipod in a vat of rice.
He turns on, this morning, much to my happiness; (there's streaks under the screen...?)
But the backlight, music, touch ability all works.
The only thing that doesn't; The wi-fi. (in settings, where the wi-fi selection is, it says "No Wi-Fi")
Is that a normal failure to happen? Or, do you think I should wait a couple of days to see if it possibly fixes itself?
Sun Nov 13 2011, 06:16PM
Inducktion wrote ...
i Had someone spill water on my cheap LG phone, after a week it was sortof working like normal, but an iTouch has way more features, therefore more prone to not recovering, wifi chips and traces are sensitive. So, your best bet is to take it apart
(if you dare) or seeing as how its gen1 just visit the Ebay and get yourself a gen 2, 3 or whatever, on the cheap .
Chip Fixes
Sun Nov 13 2011, 06:19PM
the streaks under the screen are probably water streaks, you should really leave the thing off for a week and then try it. I'm not sure on the wifi but if it doesn't bounce back you may be able to replace the wifi assembly inside the phone.
EDIT: They are pretty easy to take apart (youtube disassembly videos are your friend) as long as you have the right tools. I replace broken screens for a living.
Inducktion
Sun Nov 13 2011, 08:11PM
Also, the battery is toast. I took it apart, and the battery voltage was only at .98 volts.
Dead.
radiotech
Sun Nov 13 2011, 09:22PM
Were there any Ipod stains on the other clothes?
cheesey
Killa-X
Mon Nov 14 2011, 03:35AM
Most I know let their iPod sit in a bag of rice for 2 days and it came out fine, no damage at all.
Mon Nov 14 2011, 03:41AM
well theres the rice bag trick, then theres the flower silica you can buy from michaels or craft stores, they sell large containers of the desicant you find in pill bottles, for desicating flowers i presume. Not sure if the cost is worth it though.
Mon Nov 14 2011, 11:08AM
The usual way of drying electronics is:
Take unit apart and remove all batteries as soon as possible. If they're left in, electrolysis will soon eat through thin PCB traces, causing permanent damage. Don't forget to remove the backup battery if fitted.
Wash the circuitry in distilled water or isopropyl alcohol. It is OK to let it soak for a while. Both pure water and IPA are non-conductive, we are trying to wash away the conductive impurities in whatever the unit originally got dunked in. Bob Pease recommended putting stubborn boards in the dishwasher, but I wouldn't go that far! smile
Leave to dry in a warm area for a good bit of time (about a day) then reconnect the batteries and try your luck.
A bag of rice seems delightfully random. OK, I know it is not easy to take apart an iTouch and get the batteries out, but it really is important.
Dr. Drone
Mon Nov 14 2011, 03:13PM
shades
Mon Nov 14 2011, 05:59PM
I have to agree with the taking it fully apart comments.
