  • Guests: 47
MMC Bleeders for DRSSTC
kiat
Sat Nov 12 2011, 06:25AM Print
kiat Registered Member #2115 Joined: Fri May 08 2009, 01:17PM
Hi,
Since the MMC is connected in series with the primary of a DRSSTC then to the outputs of the H-bridge, why are high voltage bleeders across the MMC needed when a lower voltage resistor could just be placed across the H-bridge (upon power off, they will effectively be in series with the caps).
Or, are MMC bleeders even needed at all?
Thanks
Kiat
Herr Zapp
Sat Nov 12 2011, 04:39PM
kiat -
In a string of series-connected capacitors, it's possible for individual capacitors to remain charged, even though the "ends" of the string are shorted by a transformer winding or other bleed path. An individual bleeder resistor across each cap is the only way to absolutely guarantee that each individual capacitor is discharged. This is probably more of a concern in a spark-gap coil, where tank voltages are generally higher than in a solid-state coil.
Herr Zapp
Marko
Sat Nov 12 2011, 05:27PM
Hi kiat,
the bleeders don't really do anything but provide a conformal safety of knowing every cap in the string discharges after power is off, though unless some of the caps fail open or short or get drastically reduced capacitance, a single resistor across entire bank will work just as well.
In large MMC banks putting resistors over every cap may prove more nuisance than use.
Marko
kiat
Thu Nov 17 2011, 01:57PM
Ok, I understand. So bleeders are really not needed unless you want each and every cap to be fully discharged (as opposed to the MMC's terminals) after use.
Thanks again
