  • Guests: 43
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
tesla coil capacitor
technology man
Mon Nov 07 2011, 11:47AM Print
technology man Registered Member #4193 Joined: Mon Nov 07 2011, 11:21AM
hi,
i want to build a tesla coil:
hv: quad motstack
And I need a capacitor with 150nF, but a comercial capacitor is to expensive and i want to build my own highvoltage capacitor.
As insulating material, I want to use paper and oil. For the other, I need aluminium wrap.
I want to use 4 sheets of paper.
Is this good ?
And under Oil is not much corona from the aluminium wrap.
I have read, paper and oil is very good for capacitors and transformers.
greets
Ash Small
Mon Nov 07 2011, 12:39PM
I'd suggest experimenting, and see what happens.
There are guides here (some in the HV Wiki) on making capacitors, I usually use polythene as a dielectric, but paper/oil does have advantages as far as reducing/eliminating air between plates/dielectric.
I've made 200nF caps, so 150nF is easily possible, but will require some experimentation to get the correct value (I made four 50nF caps, then connected them in parallel).
technology man
Mon Nov 07 2011, 02:01PM
Ash Small wrote ...
make any caps paralell is a very good idea.
thanky.
for my last cap, i´v used overheadprojector foil but it get very much corona.
